How fast did the rock strike the ground?
A rock thrown straight up for 2.50 seconds will strike the ground with a specific velocity, which can be calculated using the equation v = u + at, where the initial velocity (u) is zero and acceleration (a) is due to gravity (9.8 m/s²). The final velocity (v) is determined to be 24.5 m/s. The discussion emphasizes the importance of identifying known variables and selecting the appropriate equations for solving physics problems. Participants express gratitude for guidance in reaching the solution. Understanding the relationship between time, acceleration, and velocity is crucial in this context.
Makaroon
A rock thrown straight up climbs for 2.50 s, then falls to the ground. Neglecting air resistance, with what velocity did the rock strike the ground?
well we are looking for v=?
we have:
t=2.50 s
and g=9.8
^do we need gravity? yes, right? =S
v= d/t
well we only have the time.
so we have to look for the distance... but the distance is ?
do we have to calculate another equation.
ahh please guide me to my answer. :S
thanks.
Hi Makaroon! :smile:
You have the initial speed (zero), and the time, and you want the final speed.
So which https://www.physicsforums.com/library.php?do=view_item&itemid=204" equation should you use? :wink:
No you don't!
hi! would this one be it?
v= u +at
and then resulting to be 24.5.
v= u +at
Yup! :biggrin:
(moral: write out all the letters you have … in this case u v a and t … and then choose an equation to fit :wink:)​
tiny-tim said:
Yup! :biggrin:
That's true.
Thank you so much!
I truly appreciate it! =]
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
