How Is Acceleration Calculated in a Pulley System with Friction?
  • Thread starter Thread starter Kingrick
    Force Pulley
The discussion focuses on calculating acceleration in a pulley system with friction, where the coefficient of kinetic friction is 0.40, and the weights of the sliding block and hanging mass are 49N and 78.4N, respectively. The initial calculation incorrectly used the weight of the hanging mass as the force pulling the block, leading to an incorrect net force and acceleration. The correct approach involves setting up separate equations for both the sliding block and the hanging mass using Newton's second law. It was clarified that the tension in the rope, not the weight of the hanging mass, affects the sliding block's motion. Ultimately, the participant found consistent results after revising their calculations based on the correct application of forces.
Kingrick
what is the acceleration of the system below? the coefficient of kinetic friction between the block and the table is 0.40. The weigts of the slideing block and hanging mass are 49N and 78.4N respectively.
Ff=uN
F=ma
Fnet= Fa-Ff
I took the 78.4N force as the force pulling the block.
then i found the Ff.
Ff= 0.4 * 49 =19.6
so Fnet = 78.4-19.6 = 58.8N
using F=ma
m= 49/9.8= 5kg
58.8 = 5 * a
a= 58.8/5= 11.76
the actual answer given is 4.5m/s^2
any help to show me where I went wrong would be great. thanks.
The force pulling on the sliding block is the tension in the rope, not the weight of the hanging mass.
Hint: Set up separate equations for each mass using Newton's 2nd law. Then solve them together to find the acceleration.
so since its moving T<mg?
would T= mg - Ff?
so T= 58.8?
Why don't you do what I suggest: Set up one equation for the sliding block (what forces act on it?) and another equation for the hanging mass.
thanks i think i got it now, i have some consistent results throughout my worksheet. thanks.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
