How Is Energy Transferred in a Spring-Launched Block on an Inclined Plane?
  • Thread starter Thread starter wanamaa
    Physics Work
The discussion centers on the mechanics of a spring-launched block on an inclined plane, focusing on energy transfer. The initial mechanical energy in the system is derived from the spring's potential energy when compressed. As the block moves up the incline, some mechanical energy converts to thermal energy due to friction, calculated using the coefficient of kinetic friction. The kinetic energy at the top of the incline is influenced by both the potential energy gained and the thermal energy lost. Participants clarify concepts of potential and kinetic energy, emphasizing the conservation of energy principle throughout the block's motion.
wanamaa
The spring in the figure shown has a spring constant of k. It is compressed a distance of x meters, then launches a block of mass m kilograms. The horizontal surface is frictionless, but the coefficient of kinetic friction for the block on the incline is µk. The vertical distance up the incline is h, and the incline makes an angle T with the horizontal. Give all answers in terms of k, x, m, µk, h, T, and g.
1. How much mechanical energy is in the system when the block is at rest with the spring compressed?
2. How much mechanical energy gets converted to thermal energy as the block travels the length of the incline?
3. How much kinetic energy does the block have when it reaches the top of the incline?
Here's the link to the picture: http://img21.imageshack.us/img21/6514/phys122.png
2. The attempt at a solution
for #1, I know that mechanical energy = Kinetic + Potential, so what I have down is ΔK + ΔU, which would be (K*ΔX) + mg, maybe? I'm most stuck on this one.
For number 2 I have thermal energy = Kmicro + Umicro, which according to the book is Ethermal = µk*mg*Δx*cos(T). This doesn't sound right to me though.
For number 3, I have that Kinetic energy = Potential + thermal, which I concluded, from the book, that kinetic = mg+(Fk * ΔX * cos(T)). Is this pretty close?
Any help would be awesome, I haven't done physics homework in almost a year, and strictly symbolic problems always throw me for a loop for some reason.
Hi wanamaa! :smile:
Well, it's at rest, so that's just the spring energy.
Energy lost to heat = work done by friction.
You're less likely to make mistakes with plus and minus signs if you write it in full …
KE + PE before = KE + PE after + work done. :wink:
Thank you! That makes so much more sense now.
I didn't post the follow up question but here it is:
"Assume spring constant k = 1000 n/M, mass m = 0.200 kg, initial spring compression x = 0.15 m, coeffiction of friction µk = 0.20, vertical height of incline h = 2.0 m, and angle T = 45 degrees.
Consider the mechanical energy the block had at the bottom of the incline. At the top of the incline, what percent of that energy is: Potential energy, Thermal energy, and kinetic energy?
Also, what distance d does the block sail through the air?"
For the first part, I feel that there will be no potential energy, since the object is in motion and that the kinetic and thermal energies depend on the equation found above. Therefore, .20*cos(45 degrees)*0.15 = 0.0212. From there I'm kinda stuck, since this only gives me the work. for the second part, I don't really know how to even start that one. Again, it's been a while since I've used physics equations, any help again would be awesome and I'll try to figure it out on my own as well.
Sorry, that makes no sense …
PE depends on height, and so long as the height has increased, so has the PE
in fact that's the whole point of PE … you can find it just by knowing where you are, not how you got there or how fast you're going
(remember, KE + PE = constant … if we ignore work done … so as you go up, your KE must decrease, so your PE increases)
Find the KE, that gives you the speed, you know the angle (45º), so use the usual projectile equations to find the range. :wink:
oh ok, I guess I got potential energy and kinetic energy confused then, when I said there'd be no potential energy. What you said makes a lot of sense, actually. Thanks a bunch for your help! :)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
