How is the 2nd law of thermodynamics related to the uncertainty principle?
The discussion centers on whether the Second Law of Thermodynamics has a quantum mechanical origin. Participants argue that thermodynamics can be derived from classical statistics, emphasizing that quantum evolution is time symmetric and does not negate entropy's directional increase. The concept of the "thermodynamic arrow of time" is highlighted, indicating that entropy increases in one direction despite quantum mechanics. Additionally, while the Second Law can be derived from classical systems, the relationship between entropy and quantum mechanics is acknowledged, particularly through the entanglement of states during interactions. Overall, the conversation underscores the interplay between classical and quantum perspectives in understanding thermodynamic principles.
quantumkiko
Does this suggest that the 2nd law of thermodynamics has a quantum mechanical origin?
Science news on Phys.org
No, since thermodynamics can be derived from statistics of ideal classical bodies (and quantum evolution is time symmetric).
People have indeed shown such a relation. I noticed a professor here has posted a popularized article about this on his door (I think it may be scientific american, so I may be able to provide a link). I'll check next time I pass by his door.
Yes, quantum evolution is time symmetric. But that doesn't prevent entropy from increasing in one direction. Hence the notion of "thermodynamic arrow of time" (time increases in the direction of entropy increase).
Also, statistical mechanics is usually taught as a quantum theory (working with the multiplicity of states having the same macroscopic state values of, for instance, the total energy). So this doesn't need to be an issue of "ideal classical bodies".
Usually ideas relating entropy increase and quantum mechanics use the fact that as things interact their states become entangled.
quantumkiko said:
How is the 2nd law of thermodynamics related to the uncertainty principle?... Does this suggest that the 2nd law of thermodynamics has a quantum mechanical origin?
What does "this" mean?! You haven't described any statement/fact/experiment/theory to refer to!
The Second Law is derivable from classical systems, so no, I wouldn't say it has a quantum mechanical origin.
Did you read the other posts?
Anyway, I checked the professor's door and it is still up. I can't find a free link to it, but googling I did find someone who put up an editorial of the article and goes over the main points:
http://wwwrsphysse.anu.edu.au/~tas110/Teaching/Lectures/L5/Material/Lloyd06.pdf
You can get the reference to the main article from there.
Thanks for the link. OK, I see what you mean; the behavior on which the Second Law relies has a QM origin (because the behavior of all matter has a QM origin). My point was only that one can derive the Second Law from classical ensembles (as Gibbs did) and apply it to all sufficiently large systems with knowing any QM. But you're right; a deeper knowledge of randomness is valuable and will no doubt advance our science.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
