How is Total Displacement Calculated for a Two-Part Train Journey?
  • Thread starter Thread starter aaquib
    Displacement
To calculate the total displacement for the train journey, first determine the displacement for each segment of the trip. The train travels 58 km at an average velocity of 77 km/h, which can be used to find the time taken for this segment. After a 5-minute wait, the train travels for half an hour at an average velocity of 64 km/h, allowing for the calculation of the second displacement. The total displacement is simply the sum of the two distances traveled during each segment. Understanding average velocity as the ratio of displacement to time is crucial for solving this problem.
aaquib
A train travels 58km at an average velocity of 77km/h[E] waits for 5min, and then runs for half an hour at an average velocity of 64km/h[E]. Find the total displacement.
HOW?!?? I am so confused. I have a test tomorrow and my teacher is useless. Please help me pass this course.
You shoudl know that aevrage velocity is given by
\overline{v}_x = \frac{\Delta x}{\Delta t}
so if you have the time and the average velocity you may find the displacement. Find the displacements for each of the two different intervals and simply add them up. That's really that simple.
I only have the time for the second part though. It doesn't tell me how long it travels for until after it stops.
distance = velocity / time
You know 58km at an average velocity of 77km/h so you only have one variable, time.
For the second part it tells you that it last half an hour!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
