How Is Work Calculated in an Isothermal Expansion of an Ideal Gas?
The discussion focuses on calculating work done during an isothermal expansion of an ideal gas, specifically a 5-liter gas initially at 300K and 10atm, expanded to a final pressure of 1atm. The method involves using the ideal gas law (PV=nRT) to determine the number of moles and applying the formula for work done, W = -nRTln(Vf/Vi). The change in internal energy (dU) is zero, leading to the conclusion that heat absorbed (dQ) equals the negative of work done (-W). Additionally, the change in enthalpy is confirmed to be zero due to the nature of the process.
  • Understanding of the ideal gas law (PV=nRT)
  • Knowledge of thermodynamic principles, specifically isothermal processes
  • Familiarity with the first law of thermodynamics (dU=dQ+W)
  • Concept of internal energy and its dependence on temperature for ideal gases
  • Study the derivation of work done in isothermal processes for ideal gases
  • Learn about the implications of the first law of thermodynamics in different thermodynamic processes
  • Explore the relationship between internal energy and temperature for various types of gases
  • Investigate real gas behavior and deviations from ideal gas laws
Students studying thermodynamics, physics enthusiasts, and professionals in engineering fields focusing on gas laws and thermodynamic processes.
Sixty3
5 litres of an ideal gas which is initially at 300K and 10atm, and is expanded to a final pressure of 1atm. Find work done, change in internal energy, heat absorbed and change in enthalpy of the system if the process is isothermal and reversible.
PV=nRT
dU=dQ+W
I just want to check if I have the correct method here.
So using PiVi=nRT to find the number of moles, then the work done is -nRTln(Vf/Vi), where Vf/Vi is the ratio Pi/Pf. Because it is an isothermal process dU=0 → dQ=-W. Also the change in enthalpy will be zero.
Thank you for any help.
(I have posted this here because there is a second part to the question which I may need help for, but I just want to check if I have the right idea).
Hello, sixty3.
Your work looks good to me.
Looks good. You may want to add why dU=0, because for an isothermal process, in general dU is not necessarily zero. It is true because dU, for a system which changes its volume by dV and temperature by dT, dU is also given by:
\textrm{d}U=C_V \textrm{d}T + \left ( \frac{\partial U}{\partial V} \right )_T \textrm{d}V
And you also know that for a perfect gas, U(T)=U(0)+C_V T, the internal energy for a perfect gas has no volume dependence because there are no intermolecular interactions.
10K
