How Long Does It Take for Charge to Reach 1/e of Maximum in an RC Circuit?
To determine the time for the charge on a capacitor in an RC circuit to reach 1/e of its maximum value, the relevant equation is q = Q_final[1-e^(-t/RC)]. The maximum charge, qmax, occurs as time approaches infinity. To find the time when the charge reaches 1/e of qmax, replace q with qmax/e in the equation and solve for t. The confusion arises from miscalculating or misunderstanding the relationship between qmax and Q_final, which are indeed equal. Clarifying these concepts and correctly applying the formula will lead to the right solution.
auslmar
A 1.47 micro F capacitor is charged through a 123 Ohm resistor and then discharged through the same resistor by short-circuiting the battery.
While the capacitor is being charged, find the time for the charge on its plates to reach 1/e of its maximum value.
q = Q_final[1-e^(-t/RC)], (q)/(Q_final) = [1-e^(-t/RC)]
Firstly, forgive my ignorance.
Well, I know that when charging an RC-circuit, the current decreases exponentially with time and the charge on the capacitor increases with time as the capacitor charges. Using the above equation, I assume we should be able to calculate a time constant, when t = RC, so that the charge would be 1-1/e of its final value. Though this will probably be straightforward to everyone else here, it's still not clear for me how to approach this. If I straightforwardly find the product of the capacitance and resistance, I'm only finding the aforementioned 1-1/e of the maximum value, correct? I'm beginning to become very muddled about this problem, and I can't tell if I'm fudging the the math (perhaps I just need an Algebra problem-solving review), or if my conception of the problem is way off. If anyone can provide a suggestions or hints as of how to approach this problem, I would greatly appreciate it. I apologize if this has been a waste of your time.
Thanks,
Austin
First off, they're asking you to find 1/e of qmax. If you look at the equation you've typed out, the max value is when t is infinity (or a very large amount of time compared to the rest of the quantities). This gives you qmax.
Then replace q by qmax*1/e in the same equation and calculate the time required from that.
Okay. Would this mean that q_max and Q_final are equal? I'm inclined to say no because I keep reaching the same (wrong) calculation. I can't figure out any way to find them without eliminating them from both sides of the equation. I keep getting that t=RC, which I know is wrong. What am I not understanding?
Thanks for your help, I finally figured it out. I think I was just miscalculating and making some stupid mistakes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
