How Low Can a Pop Bottle Go in Pitch?
The discussion centers on the theoretical limits of pitch achievable in a closed tube, specifically a pop bottle. It highlights that the human ear can only perceive a limited range of frequencies, suggesting a practical limit to the lowest note. Additionally, it notes the inverse relationship between frequency and wavelength, indicating that at very low frequencies, the wavelength may exceed the tube length, making it impossible to produce those notes. These factors contribute to the conclusion that there is indeed a limit to the lowest pitch achievable in such a setup. Understanding these principles is essential for exploring sound production in closed tubes.
Numzie
Is there a theoretical limit to the lowest note achievable in a closed tube(Pop bottle)?
Heres the question in context:
I've got what I believe to be the correct:
http://img141.imageshack.us/img141/9301/1azw1.jpg
^^ May want to check that, if you don't mind ^^
I've searched all over for something but can't find anything. From what I can reason there would be a limit for two reasons:
1) Because the human ear can only hear a limited about of frequencies.(I assume this is correct but doesn't really relate to the given situation)
2) Frequency and wavelength are inversely proportional so eventually at a low enough frequency the wavelength will be so great that 1/4 of its wavelength is greater than the length of the tube.
