How many years would it take for the glacier to move .74km?
  • Thread starter Thread starter doggerz
    Years
A glacier moves at a speed of 41 nanometers per second, which converts to approximately 4.1 x 10^-11 kilometers per second. To determine how long it would take for the glacier to move 0.74 kilometers, the time is calculated using the formula t = d/v. This results in a time of about 5013550.136 hours, which is roughly 572 years. The calculations highlight the extremely slow movement of glaciers over time.
doggerz
omg help!
ok ppl I am having trouble with this problem...
A glacier moves with a speed of 41 nm/s. How many years would it take for the glacier to move .74km? answer in units of yr.
ok and this is what I've done...
i changed 41 nm to km which i got as 41*10^-6 ...
and then i divided it by 0.74 and got some weird number like 31536000
ur somebody please tell me how to do it
first of all, a nanometer is 10^-12 kilometers
so the velocity would actually be 4.1*10^-11 km/s
now we convert this into km/h, so:
(4.1*10^-11)*3600 = 1.476*10^-7 km/h
now to get time it would take, we obviously use t = d/v:
t = (0.74)/(1.476*10^-7)
t = 5013550.136 hours
which is approximately 572 years
thanks so much u basically helped me through half of my homework! u guyz are awesome at this site!
