How Much Charge Does a 3cm Section of a Charged Line Hold?
The discussion revolves around calculating the charge contained in a 3cm section of a charged line, given an electric field of 830 N/C at a distance of 0.475m. The initial approach incorrectly applied the formula for an infinite plane instead of a line of charge. The correct method involves using Gauss's Law with a cylindrical Gaussian surface to account for the line charge's cylindrical symmetry. The user acknowledges the error and seeks guidance on the appropriate calculation for a line of charge. The conversation highlights the importance of using the correct formulas in electrostatics.
sckeen1988
The electric field 0.475m from a very long uniform line of charge is 830 N/C.
How much charge is contained in a section of the line of length 3.00cm?
My solution:
the Electric field from an infinite plane is
E=σ/(2*ε0), so σ=E*ε0*2=1.47*10^-8
3.00cm=.03m
.03*1.47*10^-8=4.41*10^-10
This answer is showing to be wrong
Just realized my problem was that my work was for a plane, not a line of charge. I'm not sure how to solve this for a line of charge though
A line charge has a cylindrical symmetry, so apply Gauss's Law using a cylinder as your Gaussian surface.
Thanks for the help, forgot to reply at the time due to my astonishment that I had not thought of that.
