How much does the temperature of an auditorium increase when filled with people?
To determine the temperature increase in an auditorium filled with 823 people, the calculation involves the room's volume of 4350 cubic meters, the specific heat capacity of air, and the heat generated by the occupants. The total energy output from the people is calculated as 148,140,000 joules over 30 minutes. The proper application of the formula Q = mc(delta T) requires using the correct density of air, which is 1.2 kg/m³. The discussion highlights the importance of ensuring all values are in standard units for accurate results. The final temperature increase calculation needs to be adjusted based on these corrections.
Xandu
I've been trying to solve this for about a week and I'm not sure where I'm going wrong.
The problem is to figure out how much the temperature of the auditorium increases when its full of people.
The room is 4350 cubic meters.
The meeting lasts 30 minutes (1800 seconds)
The specific heat capacity of air is 1.005 J/gram, or 1005 kJ/Kg
The mass of air is 1.2 kg/m
There are 823 people.
Each person gives off about 100 watts per second.
I've been using the equation Q = mc (delta T)
To get Q, I do 823 * 100 * 1800, which is 148,140,000
So then I do 148,140,000 / 1.2kg/m (1005kJ/Kg) ( 4350), which is 148,140,000 / 5,246,100 = 28.238 degrees Celsius, which is way off. them.
Quick note: watts is a measurement of energy per time so I think you mean each person gives off 100 watts (100 joules per second). Also I think you mean the density of air is 1.2 kg/m3
Make sure you are using all standard units. (Notice that the specific heat is given as kiloJoules per kilogram.
Yes, i meant 100 joules per second, my mistake, I'll try it again with 1.3 kg/m3. Thanks
No sorry that was a typo on my part. If it's given as 1.2 then use 1.2.
My main point was to make sure your values are in joules.
Oh, that makes sense, thanks.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
