How Much Mass to Hang for Different Standing Wave Loops?
The discussion focuses on calculating the mass required to produce standing waves on a string attached to a 57 Hz mechanical vibrator. Given the string's mass per unit length of 4.4 x 10-4 kg/m and a length of 1.50 m, participants explored the necessary mass for one, two, and five loops of standing waves. Key equations utilized include the wave velocity equation, v = √(T/(m/L)), and the wave frequency equation, f = 1/(2π)√(g/L). The calculations lead to a required tension and corresponding mass for each scenario.
  • Understanding of wave mechanics and standing waves
  • Familiarity with the wave velocity equation, v = √(T/(m/L))
  • Knowledge of frequency and wavelength relationships in wave physics
  • Basic algebra for solving equations related to tension and mass
  • Research the derivation and application of the wave equation in different mediums
  • Learn about the relationship between frequency, wavelength, and wave speed
  • Explore the effects of tension on wave propagation in strings
  • Investigate practical applications of standing waves in musical instruments and engineering
Students and educators in physics, mechanical engineers, and anyone interested in the principles of wave mechanics and their applications in real-world scenarios.
chazgurl4life
One end of a horizontal string is attached to a small-amplitude mechanical 57 Hz vibrator. The string's mass per unit length is 4.4 10-4 kg/m. The string passes over a pulley, a distance L = 1.50 m away, and weights are hung from this end Assume the string at the vibrator is a node, which is nearly true.
What mass m must be hung from this end of the string to produce a standing wave with the following number of loops?
(a)one loop-----kg?
(b) two loops----------kg?
(c) five loops -------------kg?
Hi chazgurl, you should have realized by now that we do not hand out help or solutions unless you have shown some prior working.
HINTS: (1) Equation for the velocity of a wave on a string.
(2) Wave equation.
~H
frequency= 1/2pi(g/L)^1/2= so...-->4.02 Hz
vo=2*pi*frequency*amplitude=
v=+/-Vo ( 1-x^2/A^2)^1/2
i don't know the wave equation
I was thinking more of;
v = \sqrt{\frac{T}{\frac{m}{L}}}
I'm sure you do, v = f\lambda
~H
ok so...if i use v= (T/m/l)^1/2
it should be v=(.07154/4.4x10^4 kg/m/.150m)^1/2
which would turn out to be...32.7 m/s...im confused
Figure it out, step by step. Answer these questions, in order:
(1) What wavelength must the wave have to exhibit the required number of loops?
(2) What must the speed of the wave be? (Since the frequency is given.)
(3) What string tension is needed to produce such a speed?
(4) What mass will be needed to provide that tension?
11K
