How Long Can a Home CPU Run Before Overheating?
  • Thread starter Thread starter sid_galt
    cpu Home
A typical home CPU can operate safely for extended periods under normal conditions, with failure due to overheating being unlikely. Concerns about CPU longevity are often overshadowed by the risk of hard drive failure due to mechanical parts. Without proper cooling, such as a heatsink and fan, CPUs can overheat rapidly. For example, an Athlon processor can last approximately 12-17 seconds without cooling, while a Pentium may last around 30-50 seconds. Overclocking a CPU with only a factory fan increases the risk of overheating. Overall, CPUs are more likely to be outgrown than damaged from heat in normal usage scenarios.
sid_galt
How much time can a normal home CPU run before it heats up badly and gets damaged?
Computer science news on Phys.org
In normal operating conditions your more likely to outgrow the cpu than have it go bad on you. I would say you should be more worried about your hard drive going bad because of all the moving parts.
Do you mean ... without a heatsink and fan?
Pentium, I don't know, but I wouldn't suggest trying it.
Athlon, I'd say it's life would be less than a minute, maybe much less. I once had a tab break off a cpu socket so the heatsink & fan just popped off. I just heard a loud snap & while I was sitting there wondering what caused the noise -- maybe 20 or 30 seconds -- luckily the system shut itself down before the cpu (an Athlon Thunderbird) fried. The thermal compound had already liquified, run off the top of the core & baked onto the surface around it. I was amazed when I found that the thing still worked.
An athlon processor will last aprox. 12-17 seconds without a heatsink. Pentium will last a little longer. I would say aprox. 30-50 seconds. But with everything in place these processors will run for a long time. I still have a 300mghz pentium 2 that I use as backup storage and she is running strong.
also if you have just a factory fan and you overclock your cpu you run risk of overheating it that way
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
