How strong a long chain of c=c double bonds will be?
The discussion centers on the strength and stability of long chains of carbon-carbon double bonds, specifically cumulenes, in comparison to carbon nanotubes. Cumulenes, characterized by alternating double bonds, are noted for their reactivity and instability due to Peierls distortion, which affects their mechanical properties. While some theoretical calculations suggest that long cumulenes could be exceptionally strong, doubts are raised about their experimental feasibility and stability. The conversation also touches on the potential of combining these chains with nanotubes to enhance strength, although skepticism exists regarding the actual contribution of cumulenes given the inherent strength of nanotubes and the limitations posed by noncovalent interactions. Overall, the consensus leans toward the challenges of utilizing long cumulenes in practical applications due to their instability and the dominance of nanotube properties.
yonos
How strong a long chain of carbon carbon double bonds will be compared to nano tubes?
H>c=c=c=c=c=c=c=c=...=c=c=c=c=c=c=c=c=c=c=c=c<H
Chemistry news on Phys.org
They are quite reactive. Here is a chain of 6000 - but they had to wrap the chains in double-walled carbon nanotubes. I don't see any discussion about the mechanical resistance.
Two CC double bonds with a common center (that is, C=C=C ) are known as cumulenes, and as @mfb pointed out, they generally are easily isomerizable to polyalkynes (C-C≡C). The parent compound of this functionality is allene, which exists in equilibrium with propyne. Cumulenes are actually less stable than conjugated alkenes (C-C=C...) where a single and double bond alternate. This occurs because the valence π orbitals in a cumulene are at right angles to one another and so do not allow much delocalization. For conjugated species, however, the π orbitals are oriented such that an electron can delocalize over a large distance, lowering the energy of the system and stabilizing it.
I think this is more a consequence of the Peierls instability of long chains with equidistant bonds.
In the long-chain limit, cumulenes buckling to polyalkynes is due to Peierls distortion, but you don’t see the same strong bifurcation in CC bond lengths in polyalkenes like you do with polyalkynes. I couldn’t say for certain why that’s the case off the top of my head. (It’s also interesting that you see isomerization in short chain cumulenes as well. I have an idea for why this occurs, but no hard evidence.)
To the OP, I’ve seen first principles calculations claiming that long cumulenes are super strong, but I doubt they’re experimentally feasible. As @DrDu pointed out, they’re unstable with respect to Peierls distortion and long alkynes undergo interchain coupling which destroys the structure.
@TeethWhitener: What about a combination of these chains plus nanotubes, as discussed in the reference I posted? Could it contribute enough to the strength to make it interesting?
I don’t have access to the full paper right now, but I doubt it. For One, I imagine the nanotube (already a very strong material) would swamp any effect you’d see from the carbyne. Also, as far as actually using the material in bulk for its mechanical properties, the limiting factor is always going to be the weakness of the noncovalent intertube interaction. It’s the same reason the whole “elephant on a pencil” argument for graphene’s strength is so misleading.
I tend to be quite skeptical of theorists’ claims in materials science, but maybe it’s just because I’ve seen way too much vaporware in that field.
