How to calculate angle given coefficent of friction
  • Thread starter Thread starter Eats Dirt
    Angle Friction
To calculate the angle at which two objects begin to slide on a platform, the relationship between static friction and normal force is essential. The coefficient of static friction (0.4) can be used in the equation Fs ≥ μFn, leading to the condition mgsinθ ≥ μmgcosθ for motion. This simplifies to tanθ = μ, allowing the angle θ to be isolated as θ = arctan(μ). The mass of the objects cancels out, indicating that the angle is independent of their weights. Understanding this relationship helps determine the critical angle for sliding without confusion over mass effects.
Eats Dirt
two objects are suspended on a platform one weighs 10 kg and the other weighs 20 kg, the coefficent of static friction is 0.4
how to find angle each of the objects start to slide
OK so Us=Fs/Fn
0.4= Fs/Fn
Fg=9.8(10) for the 10 kg object
using the vertical and horizontal components of the fg vector i get
Fn= ma cos(theta)
Fs= ma sin(theta)
U=fs/fn
0.4=sin(theta)
cos(theta) mass and acceleration cancel out
this is where i get stuck because i have theta over theta they should cancel out and i will be left with a broken equation :( any help would be appreciated.
Also if mass cancels out how am i supposed to get different angles for each of the boxes which weigh different amounts?
You should have for motion that Fs≥μFn
so you have mgsinθ ≥ μmgcosθ. (the minimum angle of theta would be when they are equal)
Which gives you a simple relation with θ and μ.
i don't understand how you would isolate theta without it canceling out or being 1
Remember the identity tanθ = sinθ /cosθ ?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
