How to Calculate Tension in a Hinged Gate with an Off-Center Load
  • Thread starter Thread starter kontroll2007
    Gate
To calculate the tension in wire CD supporting a hinged gate, the horizontal force at hinge A must be zero, indicating that all forces at A are vertical. The problem involves a gate weighing 528 N, with hinges at points A and B, and wire CD connected at a 30-degree angle. To solve for the tension, moments should be taken about point A, considering the positions of points C and D, which are not at the corners of the gate. The discussion emphasizes the need to clarify the exact locations of points C and D for accurate calculations. Understanding these forces and moments is crucial for determining the correct tension in wire CD.
kontroll2007
A gate 4.00 m wide and 2.00 m high weighs 528 N. Its center of gravity is at its center, and it is hinged at A and B. To relieve the strain on the top hinge, a wire CD is connected to the gate at an angle of 30 degrees. The tension in CD is increased until the horizontal force at hinge A is zero. What is the tension in wire CD?
ΣF=0
Στ=0
τ=r*F
Fx=Tension(cos(30))
Fy + Tension(sin(30))=528
Tension(sin30)(4m)=528(2m)
Tension= 528N
This is very wrong, I am so lost and confused please help.
where relative to the center are the hinges and the wire located?
Hi kontroll2007! :smile:
Hint: if the horizontal force at A is zero, then that means the total force at A is vertical.
So if you take moments about any point on the vertical line through A, the contribution from A will be zero.
Does that help? :smile:
(erm … we can't help you any more until you tell us where C and D are … they're obviously not the other two corners of the gate! :redface:)
Sorry, but they would not let me put a link to the picture in the post. Ok D is above A on a post while C is on the side opposite the hinges.
|D
A |{---------- C
B |{----------
ok … so which point on the line DAB should you take moments about to find the tension when the force at A is vertical? :smile:
