How to calculate the acceleration force
  • Thread starter Thread starter Guine Ghee
    Acceleration Force
To calculate deceleration force, additional information is needed beyond the provided speed of 40 km/h and load of 1,516 kg. The discussion highlights that at a constant speed, the gravitational force on the load is zero. Clarification is required regarding the type of impact being referenced, as this affects the calculations. Specifically, the time involved in deceleration is crucial for determining the force or acceleration. Without this information, accurate calculations cannot be made.
Guine Ghee
Hi Guys & Girls,
Hereby, I am a newbie in this forum and I have a question which is regarding how to calculate the deceleration gravity force. Below is the information that I have,
1. Acceleration Speed = 40 km/hr
2. Tonne of the load on truck = 1,516 kg
So, is there any of the formulation to calculate the gravity force of the impact to the load? in "g" forces.
Hello GG, :welcome:
Sorry to disappoint you in this your first post: You don't have enough information. Also, your problem description is a bit cryptic: is it the whole story ?
And: 40 km/h is a speed, not an "acceleration speed" -- a term I don't recognize even after many years in physics
At a constant speed the g force on the load is zero.
Guine Ghee said:
Hi Guys & Girls,
The mass is 1516 kg. The speed is 40 km/h.
What kind of impact are you talking about? If you want to know the force or the acceleration you need more information, such as the amount of time involved.
