How to calculate the required specifications of a motor?
To calculate the required specifications of a motor for a reciprocating rack and pinion cutter, it's essential to determine the cutting power, which is the product of cutting torque and cutting RPM. The discussion highlights the importance of understanding the limitations of using plywood as a construction material, including fatigue and failure rates. It suggests developing a hypothetical plan with defined design limits and considering the types of cutting tools and materials suitable for a reciprocating drive. Additionally, the conversation emphasizes that calculating motor specifications based solely on mass and velocity may not be the best approach to machine design. Overall, careful planning and consideration of design constraints are crucial for successful implementation.
Kaarmugilan
I am planning to design a reciprocating rack and pinion, as shown in this figure
I plan to attach a cutter to this setup to cut anything.I need to know how to calculate the motor specifications for the given mass of the gear, cutter and cutter velocity
I plan to make it with a plywood
Basically, you need to know how much cutting power you need. It's equal to the cutting torque times the cutting rpm (in SI units).
There are some online information, mostly for metals though:
Likes billy_joule and berkeman
"Cut anything," implies this is not a purpose built design so have you asked the right question? If so Jack Action has answered your question but the limit in machine design is the platform which you've chosen to be of plywood. What are the limits of your plywood design? Calculating for a motor based on the mass of the gear, cutter and cutter velocity seems to me to be an odd approach to machine design. Have you considered the fatigue and failure rates of plywood? What's the designed safety margin?
I read something here about homework and projects. If that's what this is I would suggest you begin by developing a hypothetical plan with design limits for the use of your machine. Your first limit is obvious and involves no calculations. What cutting tools can be used in a reciprocating drive and what materials can be cut with a reciprocating cutter? I assume the purpose of your design is to convert rotational motion into oscillating or reciprocal motion? For what it's worth these are just some thoughts and considerations for your design.
Likes Anas Maher
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
