How to Calculate Work Done with Vectors?
  • Thread starter Thread starter LondonLady
    Vectors
To calculate the work done by a force vector on a particle, the formula dW = \vec{F} · d\vec{r} is used, where d\vec{r} represents the change in the position vector. The initial and final positions of the particle are given, allowing for the determination of d\vec{r} as the difference between these two vectors. The work can be expressed as W = ∫(from r_o to r) of (F_x i + F_y j + F_z k) · (dr_x i + dr_y j + dr_z k). This integral simplifies the calculation by breaking down the components of the force and displacement. Understanding these vector components is crucial for accurately calculating the work done.
LondonLady
Hello again
I have another question!
Suppose a particles initial position is \vec{r_1} = 2\vec{i} + 5\vec{j} - \vec{k} metres and its acted upon by a force \vec{F} = \vec{i} + \vec{j} + \vec{k} Newtons. Its final position is \vec{r_2} = -4\vec{i} + 3\vec{j} + \vec{k}. Find the work done by \vec{F}.
Ok, i have the formula dW = \vec{F}.d\vec{r} joules.
what is dr? is it simply the change in the position vector? How do I start this off?
Thankyou,
It looks to me like a
W = \int_{\vec{r}_{o}}^{\vec{r}} \vec{F} \cdot d \vec{r}
Use the components
W = \int_{(r_{x_{o}},r_{y_{o}},r_{z_{o}})}^{(r_{x},r_{y},r_{z})}} (F_{x} \vec{i} + F_{y} \vec{j} + F_{z} \vec{k}) \cdot (dr_{x} \vec{i} + dr_{y} \vec{j} + dr_{z} \vec{k})
Thankyou very much
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
