How to change scale for fringe levels at ls prepost
To achieve better contour visualization, adjusting the fringe scale is essential when dealing with large value discrepancies. The user is struggling with a contour plot where all elements appear blue due to a significant difference between fringe levels, particularly between levels 9 and 10. Suggestions include modifying the contour settings or using a logarithmic scale to better represent the data range. Additionally, implementing a custom color map can help differentiate between the values more effectively. Proper scaling will enhance the clarity of the contour representation.
ctaini
hi all..
i facing problem to get a good contour..because the scale at fringe levels so big.
for example:
level 8 = 1.224e+037
level 9 = 6.122e+036
level 10 = 0
i have 4500 element that the value from 0 to 6.122e+37..so the result that i got all in blue color because have a big difference value from level 9 and level 10.
please help me to get a good contour.
how to change the fringe scale?..
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
