How to Determine the Weight of a Board Suspended by a Spring?
To determine the weight of a board suspended by a spring with a mass hanging from it, one must consider the forces acting on the system, particularly the force of the hanging mass and the spring's force. The torque equation, Torque = Force x Distance, is relevant for analyzing the forces at play, especially if the mass is not positioned at the center of the board. The vertical orientation of the spring is confirmed, which is crucial for understanding how it supports the board. Additional information, such as the spring's extension or properties related to oscillation, may be necessary to fully solve the problem. The relationship between the spring's force and the weight of the board is key to finding the solution.
Kospike
This is a more conceptual question so I just need the steps for this. Basically the board is hanging from the ceiling by a spring, with only its bottom corner touching the ground. Near the middle (but not exactly) there is mass hanging off of the board. I need to find out how much the board weighs
Torque = Force x Distance, maybe Spring equations.
Understand how to get the force of the hanging mass, but not if the spring has any relevance to this other than being another force
It depends what facts you are given.
Is the spring vertical?
Yes the spring is vertical
You did not answer my other (implied) question. What facts are given? E.g., you might be given the spring extension, or something about oscillation, etc.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
