How to disconnect connecting rod and crank
To disconnect a connecting rod from a crank while cycling, an overriding clutch mechanism can be utilized, allowing the crank to turn without additional force. This setup enables the connection to be reestablished once the driving system is operational and the piston can effectively rotate the crank. The discussion highlights the importance of researching clutch mechanisms for this application. Participants express enthusiasm for the innovative solution and share insights on the topic. Implementing this mechanism can enhance cycling efficiency and ease of use.
Apache
I have a mechanism
wish to disconnect connecting rod and crank when i cycling so that i do nt need to use additional force to turn connecting rod also
but connect them once my driving system is set up and piston that connected to rod can rotate my crank
how can i set up this mechanism?
Great idea! I have figured it out and learned a new thing!
Thanks!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
