How to factor cos22X + cos2X = 0
  • Thread starter Thread starter Aceradonia
To factor the equation cos22X + cos2X = 0, recognize that cos22X can be expressed as (cos2X)². This allows for factoring out cos2X, leading to the equation cos2X(cos2X + 1) = 0. The solutions include cos2X = 0 and cos2X + 1 = 0. Substituting cos2X with y simplifies the problem to y² + y = 0, which factors to y(y + 1) = 0. The discussion emphasizes both factoring and solving the equation.
Aceradonia
How do I factor this?
cos22X + cos2X = 0
Welcome to PF!
Hi Aceradonia ! Welcome to PF! :smile:
cos22X + cos2X = 0
Well, cos22X is the same as (cos2X)2,
so you can factor out a cos2X. :smile:
hmm … did you mean solve, rather than factor? … then cos2x = 0 is one set of solutions, and the other is … ? :wink:
You will easy realize it, maybe (not necessarily) if you substitute for cos2X=y, you will come up with y2+y=0. Out of there: y(y+1)=0
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
