How to find combined velocity after impact in a mallet and stake collision?
To find the combined velocity after impact in a mallet and stake collision, the momentum conservation principle is applied. The momentum of the mallet before impact is Mv, which is transferred to the combined system of the mallet and stake after impact as (M+m)vc. Since no momentum is lost during the collision, the equation Mv = (M+m)vc holds true. By isolating vc, it can be expressed as vc = v/(1+m/M). This demonstrates how to calculate the combined velocity in terms of the masses involved.
Depasquale97
A heavy mallet of Mass M (see Attached file) is dropped and moves through vertical distance y before it hits the top of a tent stake of mass m, driving it into the ground a distance d. Assume that the ground offers a a constant resistance to the motion of the tent stake and mallet, which move together after impact.
Show that the combined velocity, vc, of the mallet and the tent stake after impact in terms of the mass of the mallet M, the mass of the stake m and the velocity of the mallet before impact v is given by
vc=v/(1+m/M)
I tried to use the equation; Total momentum before collision = Total momentum after collision but had no success.
You know that at the point of impact the momentum of the mallet is Mv and that momentum is transferred to the combined system as (M+m)v_c. Is any momentum lost?
If not, do the algebra.
Thank you RUber, no momentum is lost.
So then you need to show that
##Mv = (M+m)v_c \iff v_c = \frac{v}{1+\frac{m}{M}}##
Do this by isolating v_c and rewriting (M+m) as M(1+m/M).
Thank you very much, much appreciated
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
