How to find moles of O in CO molecule?
In summary: C.If you want to speak of atoms of C as a mole, then you would say 1 mole of C atoms is 6.022 x 10^23 atoms of C.In summary, the conversation discusses finding the number of moles of oxygen in a CO molecule, and suggests using the definition of a mole to solve the problem. The concept of proportion is also mentioned, along with the importance of mole calculations in chemistry. The final conclusion is that for every 1 mole of CO, there are 1 mole of C atoms and 1 mole of O atoms.
Indranil
177
If CO = 10 moles, then how to find moles of O in CO molecule?
I don't know how to proceed
Read the definition of a mole here:
https://en.wikipedia.org/wiki/Mole_(unit)
and you should be able to work this out.
Its like the old trick question of which is heavier a pound of feathers or a pound of rocks.
In the future, please provide more than I don't know as your attempt. You should research your problem and not just sit there confused. There is a way out of every maze and you can find it if you try.
From the given link, I cam to know that
2 H2 + O2 → 2H2O implies that 2 mol dihydrogen (H2) and 1 mol dioxygen (O2) react to form 2 mol water (H2O). From this concept, I can write
1 mol C and 1-mole O2 form 1 mole of CO but how to calculate moles of O if CO = 10 moles already?
I agree with the water, but what is the equation for C and O2?
When you've sorted that,
if 2 mole H2 and 1 mole o2 makes 2 mole H2O,
then how many mole of each is needed to make 10 mole H20 ? It's just proportion.
A simpler set of questions are:
If I have 1 molecule of ##CO## then I know I have 1 atom of ##C## and so how many atoms of ##O## do I have?
If I have 2 molecules of ##CO## then I know I have 2 atoms of ##C## and so how many atoms of ##O## do I have?
If the ##O ## atoms combine into ##O_2## then how many ##O_2## molecules do I have?
Basically moles are a count of the number of molecules or atoms in the sample.
Like when I say I have 1 dozen eggs I know I have 12 eggs.
When I say I have 1 mole of eggs then I know I have ##6.022 x 10^{23}## (Avogadros number) of eggs.
https://en.wikipedia.org/wiki/Avogadro_constant
The next question why are mole calculations so important to chemists?
http://chemistry.bd.psu.edu/jircitano/mole.html
https://www.khanacademy.org/science...-to-the-atom/v/the-mole-and-avogadro-s-number
then how many moles of each is needed to make 10 mole H20 ? It's just proportion.
It should be C + O2 = 2CO
10 mol H2O and 5 mol O2 make 10 mol H2O
10 H2 + 5 O2 = 10 H2O
In 1 molecule of CO, I have 1 atom of C and 1 atom of O.
so 2 molecules of CO, I have 2 atoms of C and 2 atoms of O.
10 molecules of CO, I have 10 atoms of C and 10 atoms of O. Am I right?
From your context, I have a doubt.
What do you mean by 1 atom of C? Does it mean 1 mol of C atoms?
Right. 1 C + 1 O2 = 2 CO so scale this up to give 10 CO
1 atom of C is 1 atom of C, 1 mole of atoms of C is 1 mole (6.02×1023) of atoms of C. Typically when we say "1 mole of C" we mean 1 mole of atoms of C.
Likes jedishrfu
I meant one atom of C or more properly one Carbon (C) atom. Your extension to 1 mole is okay since you're now understanding a mole to be a specific number of carbon atoms
There are no doubts only questions. In american english, doubt means to not believe something is true which can be taken to mean that you think the person is not being truthful.
The whole point of moles is understand how to create compounds like a cooking recipe.
I take one cup of carbon and 1 cup of oxygen to make one cup of carbon-monoxide (CO)
However in the real world using cups or using weights of elements or compounds will produce wasted left-over materials in the chemical process. Chemists discovered that if they can mix ingredients by numbers of atoms or molecules that ideally there will be no waste and so the mole was invented, atomic weights were measured and a whole lot of molarity and molality problems were created for students of chemistry and science.
Could you be more specific on ''one carbon atom and one mole of carbon atoms?'' what is the difference between them? Could you clarify it, please?
I think I see your point. These chemical equations show the number of each species in a reaction. They may be atoms or molecules.
For many elements an atom is also considered a molecule, but for many gaseous elements molecules have two atoms - which is why we write O2 rather than 2 O.when elemental Oxygen occurs in an equation.
So you are correct to say
Indranil said:
10 molecules of CO, I have 10 atoms of C and 10 atoms of O. Am I right? Yes.
But since oxygen molecules have two atoms, you get only 5 molecules of oxygen.
For the difference between molecules and moles you probably need
to read up on moles (and maybe Avogadro's constant.)
Basically, your equations show the number of atoms and molecules involved in the smallest unit of the reaction. Like an atom of carbon and an atom of oxygen gives a molecule of CO. But this is repeated billions of billions of billions ... of times when you react perceptible amounts of material together.
What we are usually interested in, is the mass or volume of reagents needed or produced. For this it is convenient to talk about moles.
A mole is the relative molecular mass of the substance times 1 g.
Hydrogen has atomic mass 1, molecular mass 2, so a mole of hydrogen is 2 g.
Carbon has atomic mass 12, (commonly*) molecular mass 12, so a mole of carbon is 12 g
Oxygen has atomic mass 16, molecular mass 32, so a mole of oxygen is 32 g
The actual number of atoms or molecules in the mole is not so important as the fact that 1 mole of anything contains the same number of molecules as 1 mole of anything else.
(* molecular weight is not as clear cut as you might hope! But so long as you are consistent, there is no problem.)
Edit: Blow me down! I've just reread Borek's post. This is probably a more accurate representation of the modern mole than my version. But I'd suggest that coming to it through the flawed gram-molecule may be easier to start with?
1 atom of C means 1 atom of Avogadro's numbers of C = 1 atom of 6.023 X 10^23 numbers of C atoms?
@Indranil please take some time to watch the Khan Academy video it should clarify much of your confusion.
Moles is all about numbers of atoms and molecules nothing more. To find the number of atoms we need the atomic weight of an atom or molecule so we can convert the measured weight of a compound into moles and from there into new compounds through chemical processes.
As noted earlier, 1 mole of CO is composed of 1 mole of carbon and 1 mole of oxygen atoms. If the oxygen combines into O2 then the 1mole of oxygen atoms becomes 1/2 mole of O2 molecules.
Does 1 C atom mean a single C atom of 6.023 X 10^23C atoms = 1 C atom of Avogadro's number of C atoms = 1 C atom of 6.023 X 10^23 numbers of C atoms?
Does 1 mole of C atoms mean Avogadro's number of C atoms = 6.023 X 10^23 numbers of C atoms?
I am confused. What is the difference between them (1 C atom and 1 mole of C atoms)? Could you clarify it, please?
Beware, this is not balanced.
Yes 1 C atom means one atom.
Yes 1mole Of C atoms means ## 6.023x10^{23}## C atoms.
Yes, sorry. Not sure how I mdid that (though when you're counting 1023 atoms, it's hardly surprising if you miss the odd one.)
10C + 5O2 = 10CO
Likes Bee529 and jedishrfu
Yes, I think you got it. The O2 twist always tricks students. I think it fooled me when I took chem many decades ago.
Likes Bee529
1. How do I calculate the moles of oxygen in a CO molecule?
To calculate the moles of oxygen in a CO molecule, you can use the formula:
moles of O = (mass of CO molecule / molar mass of CO) * 1 mole of O / 1 mole of CO
First, determine the mass of the CO molecule by adding the atomic masses of carbon and oxygen. Then, divide this mass by the molar mass of CO, which is 28.01 g/mol. Finally, multiply this value by the ratio of 1 mole of O to 1 mole of CO, which is equal to 1. The resulting value will be the moles of oxygen in the CO molecule.
2. Why is it important to know the moles of oxygen in a CO molecule?
Knowing the number of moles of oxygen in a CO molecule is important for various chemical calculations and reactions. It allows us to determine the amount of oxygen that will be consumed or produced in a reaction involving CO. It also helps in determining the stoichiometry, or the mole ratio, between CO and other substances in a reaction.
3. Is there a difference in the number of moles of oxygen in a CO molecule compared to other molecules?
Yes, the number of moles of oxygen in a CO molecule will be different from other molecules that contain oxygen. This is due to the different molecular structures and atomic compositions of different molecules. For example, a molecule of CO2 will have twice the number of moles of oxygen as a molecule of CO.
4. Can I use the same formula to find the moles of oxygen in any molecule?
No, the formula for calculating the moles of oxygen in a CO molecule is specific to this particular molecule. To find the moles of oxygen in other molecules, you will need to use different formulas based on their molecular structures and atomic compositions.
5. How can I experimentally determine the moles of oxygen in a CO molecule?
One way to experimentally determine the moles of oxygen in a CO molecule is through gas analysis. This involves measuring the volume of oxygen gas produced when a known mass of CO is reacted with excess oxygen. From the volume of oxygen gas produced, the moles of oxygen can be calculated using the ideal gas law.
