How to find tension of a single object in a pulley system?
To find the tension in a pulley system with a mass of 2m, the net force equation Fnet = ma was used, leading to the expression Ft = 2m(g-a). The discussion highlighted the need to express acceleration (a) in terms of mass (m) and gravitational force (g), ultimately leading to a calculated acceleration of a = g/5. Substituting this back into the tension formula yielded Ft = 8mg/5. The methodology was mostly correct, but there was confusion regarding the total mass in the system.
fissifizz
LETTER d only [/B]
Fnet = ma
So I considered 2m independently and set its net force equal to its gravity minus its tension.
(2m)a = Fg - Ft = (2m)g - Ft
I then rearranged the equation so that Ft = (2m)g - (2m)a = 2m(g-a)
There's no answer key, so I'm not sure if this is correct. I appreciate any assistance with this problem! Thanks!
The problem is that your answer contains a. The directions say to express your answers in terms of m and g.
So, you need to find an expression for a in terms of m and g.
Ah, ok. Since all the blocks are moving in a system, I'm going to assume that the acceleration calculated in letter b will be used.
Fnet = (5m)a = 5mg - 4mg (I hope I'm calculating this correctly)
(5m)a = mg
a = g/5
So time to plug back in: Ft = 2m(g-a) = 2m(g-(g/5))
Ft = 2m(4g/5)
Ft = 8mg/5
It seems like that's it. Was my original methodology correct though?
What do you mean? The blocks are connected, and the magnitude of their acceleration is the same.
The net force is correct, mg, but the whole mass is not 5m.
