How to get the distance traveled from the force and mass functions?
To determine the distance traveled by an object under a time-varying force and mass, one can derive the acceleration from the force and mass functions, F(t) and m(t), using the equation m(t)dv/dt = F(t). This allows for the integration of the resulting expression to find velocity, v(t), followed by another integration to obtain the distance function, x(t). If the functions are continuous over the interval [0, b], the integrals will be well-defined, but if they are not, one may need to interpret the behavior of the functions and potentially break the integration into continuous segments. Definite integration can be employed to sum the contributions to distance over these segments. Ultimately, the approach hinges on the continuity and behavior of the force and mass functions during the specified time interval.
Cinitiator
I have two functions:
F(t) - where F(t) is the force at a given time t
m(t) - where m(t) is the mass of the object in question at a given time t
Let's say that some force (in a thrust form) is applied to the object for "b" seconds. The function F(t) specifies in what manner.
How can I get the distance traveled by the object after "b" seconds, if we know that the velocity, acceleration and distance traveled are all 0 at t = 0?
I've tried using an analogy of the Riemann sum (diving each instantaneous force by each instantaneous mass and summing everything for an acceleration-time function), and it turned out to be too tedious and imprecise to be applied practically.
Anyone?
You can write an expression for the acceleration with respect to time from the given force and mass functions. Integrate to find velocity. Integrate again to find distance.
Thanks for your feedback. Can one just successively integrate the force function dived by the mass function to get the distance function?
Sure.
m(t)dv/dt= f(t) so that dv= (f(t)/m(t))dt and you can integrate that. Once you have found v(t), you can use dx/dt= v(t) and integrate dx= v(t)dt to find the distance function. Of course, there is no guarantee that any of those functions will be "integrable" as an elementary function.
But what if the F(t) and m(t) functions aren't continuous, and are only continuous on the interval of [0, b]? It's easy to do the calculations when the function is completely continuous. But how to do it if it's continuous only over [0, b], and we want to know the distance traveled at b?
:confused: If they're continuous over [0,b] and you want the distance at b, I don't see the problem since the integrals will be defined over the domain.
If the functions are not continuous then it is up to you to interpret their behavior in terms of physical laws and deal with the implications. This might, for example, mean splitting the domain of integration into continuous pieces and "bridging" the gaps with assumed constant velocity sections.
Can one use definite integration for that?
Sure. Any integration is just a sum. A sum can be split into chunks and added separately. If some physics occurs between the parts represented by the integrations, then the integrations just become terms in an overall equation of motion where you stick other terms to fill in the "spaces".
Do you have some particular F(t) and M(t) in mind which is raising these concerns?
Cinitiator said:
I have two functions: F(t) - where F(t) is the force at a given time t m(t) - where m(t) is the mass of the object in question at a given time t Let's say that some force (in a thrust form) is applied to the object for "b" seconds. The function F(t) specifies in what manner. How can I get the distance traveled by the object after "b" seconds, if we know that the velocity, acceleration and distance traveled are all 0 at t = 0?
I've tried using an analogy of the Riemann sum (diving each instantaneous force by each instantaneous mass and summing everything for an acceleration-time function), and it turned out to be too tedious and imprecise to be applied practically.[/QU
