garylau
- 70
- 3
✱✱ members are reminded that homework help requests must use the 3-header template provided ✱✱
Did i make mistake in my calculation?blue_leaf77 said:Yes you can also do that, and may be in the third line you can use the fact that the derivative of ##\sec x## is ##\sec x \tan x##. But your way is kind of longer than necessary.
Looks good. Now you only need to do the last integral and change back to the original variable ##u## and plug in the integral limits.garylau said:Did i make mistake in my calculation?
If you use this substitution,cnh1995 said:Use the substitution
√(2u+z2)=t.
Oh i see thank youcnh1995 said:If you use this substitution,
du/√(2u+z2) can be replaced by 'dt' and u+z2=(t2+z2)/2.
So, you'll simply get it as ∫2dt/(t2+z2) which is (2/z)tan-1(t/z).
You get your answer in just two steps.
blue_leaf77 said:Looks good. Now you only need to do the last integral and change back to the original variable ##u## and plug in the integral limits.
i don't know why i do it wrong (is there a minus sign??)blue_leaf77 said:Looks good. Now you only need to do the last integral and change back to the original variable ##u## and plug in the integral limits.
I don't know why you are redoing your work, you are almost there in post #5.garylau said:i don't know why i do it wrong (is there a minus sign??)
can you help me to check it
thank
blue_leaf77 said:I missed one mistake in your work in post #5. In the last line, you should have removed the integral and the integration element. There should only be #\theta## there.
yesblue_leaf77 said:I missed one mistake in your work in post #5. In the last line, you should have removed the integral and the integration element. There should only be #\theta## there.
what if i try to integrate it using multiple integration...seems quite tough then...can you help regarding that??cnh1995 said:If you use this substitution,
