How to model a non-linear pendulum with air resistance?
The discussion revolves around modeling a non-linear pendulum with air resistance, specifically focusing on the effects of varying the area on damping. Participants are analyzing differential equations that describe the motion of the pendulum and comparing it to other damped systems.
  • Participants discuss the formulation of the differential equation and the implications of using a resistive force proportional to \(v^2\). Questions are raised about how to properly account for directionality in the resistive force. There is also a focus on the relationship between the area and damping coefficients.
Some participants have offered insights on the formulation of the differential equation and suggested numerical methods for solving it. There is an ongoing exploration of how changing the area affects damping, with references to external resources for further analysis.
There are references to previous discussions regarding the correctness of the differential equation, and some participants express uncertainty about how to eliminate specific problems related to the model. The original poster has provided links to resources that may aid in understanding the concepts discussed.
Omkar Vaidya
I have found a differential equation that models a non-linear pendulum with air resistance, and now I have data. I've looked at the following site for guidance on how to analyse the data. It compares the motion of a damped spring, and compares it to the motion of a damped pendulum. However, my equation involves a v^2 (or (dtheta/dt)^2. The equation in the site has v proportional to the drag force. The question I am trying to answer is "How does changing the value of A(area) affect damping?"
https://prnt.sc/i6bfv0[/B]
Omkar Vaidya said:
I have found a differential equation that models a non-linear pendulum with air resistance, and now I have data. I've looked at the following site for guidance on how to analyse the data. It compares the motion of a damped spring, and compares it to the motion of a damped pendulum. However, my equation involves a v^2 (or (dtheta/dt)^2. How would I eliminate this problem?
As already pointed out in another thread on this problem, your differential equation is incorrect. You cannot have a resistive force of ##k v^2##, because that always points one way (always either to the left or to the right). You need a force that changes direction when the pendulum reverses its motion. That can be done using ##k v^2\: \text{sign}(v) = k v |v|##.
I don't think you can "eliminate" the problem; you can only deal with it. If you have access to a good numerical DE solver, getting a reliable numerical solution should not be much of a problem. In another thread on this problem I presented solutions obtained by Maple.
Yes, I think that would be my question too. I did change the v^2. However, the question I am trying to answer (sorry for not including that) is "How does changing A(area) affect damping?" That is where the site comes into use, by comparing damping coefficients.
Your post speaks of a "site", but does not give a link.
  • · Replies 46 ·
