Hydrolics, Forces and flow rate.
The discussion focuses on calculating the forces involved in raising a traffic barrier using hydraulics. The motor specifications include a speed of 1400 rpm and a torque of 200 Nm, while the lobe pump delivers 1.5 l/min of hydraulic oil through a 50mm² hose to a piston of 1320mm². The original poster seeks guidance on determining the force exerted by the pump/motor on the fluid, specifically using mass flow rate. Clarifications reveal that the barrier in question is a parking barrier, not a railway arm, and that there is no counterbalance involved. Additional formulas and resources are shared to assist in the calculations.
GuitarWill88
Hi, I'm currently trying to work out the forces involved in raising a traffic barrier.
It works using hydrolics.
It has a motor that has a speed of 1400 rpm and 1/3 hp. the torque of the motor is 200Nm
the pump is a lobe pump and has a delivery of 1.5 l/min.
The pump will move the hydrolic oil through a hose 50mm2 and then into a piston of 1320mm2
I need to work out the force that the pump/ motor is exerting on the fluid. However i am not sure how i can do this only using the mass flow rate.
If anyone can tell me if this can be done/ how to do it would be great. If there is any additional information needed to solve this problem i can probably provide it.,
Thank, Will.
By traffic barrier do you mean one of those arms that drop down by railway lines? They have a counterweight opposite the arm that basically cancels the weight of arm so you don’t have to lift very much. For the hydraulics you must decide how fast you want it to operate as well as the force needed. Here are some formulas to get you started:
http://www.hydraulic-systems.com/pages/ref_formulas.htm
Thanks, those formulas have been quite useful.
By parking barrier i meant the type of barrier use in car parks to let you in/ out. The are usually powered using an electric motor or a hydrolic pump. The is no counter balance
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
