I am trying to get fimilar with electrical components. I did some BG
The discussion revolves around understanding electrical components, specifically relays, and their application in controlling devices such as lights. Participants share their experiences and seek clarification on wiring and functionality, as well as troubleshooting issues related to relay integration with other devices.
  • Homework-related
  • One participant describes the need for a relay to control a component, explaining the function of normally open (NO) and normally closed (NC) configurations in relation to a switch and a light.
  • Another participant expresses uncertainty about the correct relay to use with a specific camera and mentions difficulties in connecting it to turn on a light.
  • A third participant attempts to clarify the initial post by confirming the understanding of a low voltage circuit activating a relay capable of switching mains voltage.
  • There are indications of confusion regarding the necessity of a switch when using a normally open relay configuration.
  • One participant acknowledges a mistake in a circuit diagram and seeks to correct it, indicating ongoing exploration and learning.
Participants do not appear to reach a consensus on the correct application and wiring of relays, with multiple viewpoints and uncertainties expressed throughout the discussion.
There are unresolved questions regarding the specific relay compatibility with the Axis camera, as well as the correct wiring configurations for the intended applications. Some assumptions about voltage levels and relay capabilities remain unverified.
Individuals interested in learning about electrical components, particularly relays, and their practical applications in circuit design and control systems.
math111
I am trying to get fimilar with electrical components. I did some BG research on relays. Does this make sense.
1.My systems needs a switch to control a component so that is why I need a relay. It is a micro-switch that will move towards its position(Normally open or Normally Closed) depending on the incoming power over the coil based on how it is wired to NO and NC to the component I am trying to control with the switch.
2. My basic relay diagram below controlling a light(Wired for normally open)
-No power switch is off, Power switch is on.
Switch(Rated at different Power)-<>-----Relay----<>-----Light(At a different Power)
incoming power-->Power of switch-----------------<>-----Relay----<>-----power of light
3. If hooked up in Normally open and I power it on do I even need a switch to turn the light on if it goes on autmatically? If so then would I hook it up thru Normally closed to use a switch to turn it on and off??
This is all new to me so lead me in the right direction so I can pick and choose relays for a project! even the most basic!
Does both my statements make no sense?
Hi,
I do not know anything about relays. I been trying for days to hook up a relay to turn on a light using an Axis camera with an I/O switch. This is the relay http://search.digikey.com/scripts/Dk...536&DPU=submit
This is the manual for the Axis 207 207W camera http://www.axis.com/files/manuals/um...58_en_1208.pdf . the camera is 3.3 volt with a max 50ma, I don't even know if this is correct relay. I’m willing to pay someone for help me make this work.
This company http://www.ibou.fr/cameras/cameras.html makes something that works but they are asking 70 euro=110 dollars plus 30 shipping and the relay cost is only 4 dollars. For a relay that cost 5 dollars. I know they need to make a profit but this outrageous.Thank you
kardamyla ... please don't hijack other people's threads, its rude, start your own one :)
math111 ... been rereading your post and trying to clarify it :)
I think what you are getting at is you have a low voltage circuit (say 12VDC) that is going to activate a relay that is capable of switching mains voltage say 120 or 220VAC (depending on where in the world you are ) is that correct?
maybe something like this circuit I have drawn ?
cheers
Dave
Sorry about that
oops mad a major boo boo in that circuit... too early in the morning and before my first cup of coffee ;)
lets try again...
cheers
Dave
  • · Replies 25 ·
