I-beam section free vibration on ansys
The discussion centers on conducting a thesis analysis of free vibration in I-section beams made from composite materials. The user has successfully performed the analysis but is uncertain about the accuracy of the results and seeks comparative data. They mention needing additional thesis notes for reference, particularly focusing on simply supported I-section beams and their vibration characteristics. The user expresses a need for material properties and frequency results to validate their findings. Overall, the thread highlights the challenges of finding reliable comparative studies in this specific area of research.
Kerim Erol
Hello. I have to do an analysis for my thesis. It's about "free vibration of I section beam, composite material". I searched it on the internet but i did not find an appropriate thing. I can do the analysis about it but i must compare the results. So, is there anybody help me about it?
Sure can you please elaborate the problem?
I need another thesis note. i can do the analysis, i find the results but i don't know that the results is true or not.. So i'll try another thesis and i look the results.. Also, my proffessor said that" find a thesis notes, study it." Thats so, i need a thesis note. i find a thesis note about "simply supported, I section beams, free vibration, composite material".
Or property of materials and the results of frequency.. I need these.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
