I can't understand this circuit
  • Thread starter Thread starter kliker
    Circuit
The discussion focuses on understanding circuit diagrams, specifically how to simplify them for better comprehension. Participants emphasize that all connections to ground are at the same potential, allowing for the replacement of ground connections with direct wires. This simplification helps clarify circuit relationships and makes it easier to analyze. A follow-up circuit is presented, prompting further discussion on its simplification, with the consensus that the low side of the battery must be connected appropriately to make sense of the circuit. Overall, the conversation aids in grasping basic circuit concepts for solving more complex problems.
kliker
[PLAIN]http://img34.imageshack.us/img34/2739/image3sz.png
what is this circuit? can someone explain me? please I need to understand the basics in order to solve difficult exercises
thanks in advance
All the connections to the ground are at the same potential. This means that you can replace the ground connections with a straight wire connecting the other end of the battery to the other end of each resistor. Redraw the circuit then and see if it makes more sense to you.
thank you for the explanation what if the circuit was something like this
[PLAIN]http://img255.imageshack.us/img255/7705/26466399.jpg
is it possible to simplify it like you did with the first circuit?
This circuit doesn't make much sense. You show only the "high" side of the battery. What is the "low" end of the battery connected to? Assuming the convention that the "low" side is grounded, then you can remove the two grounds and connect the low end of the battery to the other end with a straight wire.
thanks I understand it now
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
