I got burned by a helium tank valve. How?
  • Context: Undergrad
  • Thread starter Thread starter polypterus
    Helium Tank Valve
The discussion revolves around an incident where a participant experienced a burn from a helium tank valve while inflating a balloon. Participants explore the thermodynamic properties of helium and the effects of gas expansion on temperature, comparing it to experiences with scuba tanks and discussing the implications of Joule-Thomson coefficients.
  • One participant notes that gas escaping from a pressurized tank typically cools, citing personal experience with scuba tanks that ice up.
  • Another participant suggests that the sensation of burning could be a misinterpretation of a flash freeze effect, although the original poster insists it felt like a burn.
  • A participant explains that helium has a negative Joule-Thomson coefficient at ambient conditions, which means it warms when expanded, potentially causing the burn.
  • Some participants challenge the extent of temperature rise, with one stating that the increase for helium is less than 10 degrees Fahrenheit, questioning the possibility of a burn.
  • Another participant corrects their earlier assumption about the type of cylinder, indicating that a higher pressure cylinder could lead to a more significant temperature increase.
Participants express differing views on the cause of the burn, with some attributing it to the properties of helium and others questioning the feasibility of such a temperature rise. The discussion remains unresolved regarding the exact mechanism behind the burn sensation.
There are limitations in the discussion regarding the assumptions made about the type of helium tank and the specific conditions under which the burn occurred. The effects of pressure and temperature changes are not fully quantified, leaving some uncertainty in the claims made.
polypterus
Hi folks. I had a strange thing happen to me and I was wondering if some of you physics gurus could explain it to me. It's my understanding that gas escaping from a pressurized tank makes things cooler. In fact I recently had to empty my scuba tanks for transport and the valves did indeed ice up as the air escaped. However the other day I found a helium tank it my garage. This is the cheap non-refillable kind you get from toys-r-us for blowing up balloons. It has two valves. A metal one you turn and then a rubber nozzle you put the balloon over and hold sideways to blow up the balloon. My four year old son was standing next to me so I decided to blow up a balloon for him. I turned the metal valve a bit, put a balloon over the nozzle and pushed it sideways. In a couple seconds the thing got so hot it actually burned my thumb and I had a blister for a few days. How could this happen?
Science news on Phys.org
There's very little, if any, difference between the effects of extreme heat and extreme cold. That applies to physical sensation as well as cellular disruption. I suspect that you flash-froze your finger and your brain interpreted it as a burn.
That crossed my mind however it really did feel like a burn. In any case I'm tempted to try it again with thermometer handy although I'm not sure how I'd use it. The other thing is my scuba tanks which are under much higher pressure do get cold however I can still lay my hands on the valve without getting injured.
At ambient conditions helium has a negative Joule Thomson coefficient so will warm when expanded - hence you burnt yourself. Hydrogen and Neon also have negative Joule Thomson coefficients at room temperatures.
Hi hamishnichol,
The rise in temperature for helium is less than 10 degrees F so there's no chance that can happen.
Q_Goest said:
Hi hamishnichol,
I'd misread the type of cylinder so assumed it was a 200bar helium cylinder which would give ~ 12K increase in temperature which on a hot day could just about push it from hot to touch to ouch!
  • · Replies 16 ·
9K
