Solving Arithmetic and Series Problems in IB Math Methods
  • Thread starter Thread starter Astronomer107
    Ib Math methods
The discussion focuses on solving two arithmetic and series problems in IB Math Methods. The first problem involves finding the first term of an arithmetic sequence with a common difference of 2 and a sum of 120, leading to the conclusion that the first term is 8, derived from the equation Sn = 120. The second problem concerns the series defined by 4 + 10 + 16 + 22 + ... + (6n - 2), with confusion about whether the series is finite or infinite, and how to express the sum as a function of n. Participants clarify that -7.5 is not a valid solution for the number of terms, as it cannot represent a negative count. The conversation emphasizes the importance of correctly interpreting the series and applying mathematical principles to derive valid solutions.
Astronomer107
I've been working on these problems for a long time trying to prove to myself that I'm not stupid (though I am convinced I am because I don't feel like "IB material" at the moment), but this will be impossible since I have other things to do. So, my two questions are these:
1. An arithmetic sequence has a common difference of 2 and a sum of 120. The first term is numerically equal to the number of terms. FInd all possible values of hte first.
I know that the answer is 8 because it is a multiple choice question and through elimination, the others aren't possible, but I don't understand how to prove this mathematically.
2. Determine Sn of the series 4 + 10 + 16 + 22+...+ (6n - 2).
I tried to solve this one, but when I did, the n's canceled out, making it "all real numbers" and since (6n - 2) is the last term, the series isn't infinite.
PLEASE HELP ME! Thanks!
1) The series is: [sum] [ x + 2*y] from y = 0 to x-1
To solve an arithmetic series it is 1/2 times the size of the series times the quantity of the first term plus the second
Sn = (1/2) * n * ( a1 + a2 )
the first term you know is the number of terms in the series and the last term is equal to n+2*(n-1) based on the equation.
So..
Sn = (1/2) * n * ( n + [ n + 2*(n-1) ] )
Then you solve Sn = 120
And you get n = 8 and -7.5
2) I'm unsure what your asking
the series is
[sum] 6x-2 from x=1 to ?
your saying the series isn't infinite, so what is it?
if the series goes from x=1 to infinity then the series diverges
the series is
Thanks for the help on the first question. I was assuming the series was finite because (6x - 2) is the last term in the series. Another question: I don't understand how -7.5 can be relevant because it says that n is equal to the number of terms, but there can't be -7.5 terms... can there?
I think that what the question for is the sum as a function of n.
Sn = F(n)
What you would do is write out the summation, and then use the rules that you know to reduce it into a formula.
For example:
[sum]c from i=0 to n = cn (c is a constant
[sum]i from i=0 to n = 1/2(i+1)*i
Astronomer107: -7.5 can occur in a quasi-hyperdimesion manifold, that is forumalated by using the...
No, you are right, -7.5 isn't an answer. (Only in my imagination)
Also, what are the choices for question 2.
Is there an answer: n*(3*n+1)
