How Is Volume Affected by Pressure in an Ideal Gas?
The discussion centers on calculating the volume change of a monatomic ideal gas under adiabatic compression from an initial pressure of 110 kPa to a final pressure of 150 kPa in a thermally insulated container. The key equation for this scenario is the adiabatic condition, which states that P_iV_i^γ = P_fV_f^γ, where γ is the heat capacity ratio. Participants clarify that the relationship between pressure and volume during adiabatic processes differs from isothermal processes, emphasizing that temperature also changes. The ideal gas law remains applicable, but adjustments must be made to account for the adiabatic nature of the compression. Ultimately, the correct approach involves using the adiabatic condition to find the new volume.
MozAngeles
A monatomic ideal gas is held in a thermally insulated container with a volume of 0.0900m 3. The pressure of the gas is 110 kPa, and its temperature is 347 K.
To what volume must the gas be compressed to increase its pressure to 150 kPa?
PV=nRT
\Delta=Q-W
W=P\DeltaV
P1*V1/P2
=(110*.09)/(150)
= .0660 this is wrong i don't know what I'm missing..
PV=nRT
\Delta=Q-W
W=P\DeltaV
P1*V1/P2
=(110*.09)/(150)
The key is the thermally insulated container. What kind of compression is this? What is the relationship between P and V in such a compression? (hint: it has something to do with \gamma)
AM
So it is a adiabatic compression right?
So would I use
PiVi\gamma=PfVf\gamma
So would I use
If you mean:
P_iV_i^{\gamma} = P_fV_f^{\gamma}
ie: PV^{\gamma} = K = constant
then, yes
AM
and then for the second part of the question I am still stumped, I thought you could use
Vi/Ti=Vf/Tf
and this isn't right, probably because of the fact that it is adiabatic?
but the equation is PV\gamma= constant
so that doesn't include temperature, and now I'm lost..
Vi/Ti=Vf/Tf
Vi/Ti=Vf/Tf is true only if P is constant. In an adiabatic change, P, V and T all change. The ideal gas law still applies. But in order to determine how T changes you have to know how P and V change.
If you substitute P = nRT/V into the adiabatic condition, it becomes:
TV^{(\gamma-1)} = PV^\gamma/nR = K/nR = \text{constant}
That is what you have to use.
AM
thanks figured it out
