Identifying and Classifying Singular Points in Differential Equations
Ted123
Locate the singular points of x^3(x-1)y'' - 2(x-1)y' + 3xy =0 and decide which, if any, are regular.
In standard form the DE is y'' - \frac{2}{x^3} y' + \frac{3}{x^2(x-1)} y = 0.
Are the singular points x=0,\pm 1\;?
Regular singular points x_0 of y'' + p(x)y' + q(x)y =0 satisfy (x-x_0)p(x) ,\; (x-x_0)^2q(x) both finite as x \to x_0.
Considering x \left( -\frac{2}{x^3} \right),\; (x-1) \left( -\frac{2}{x^3} \right) ,\; (x+1) \left( -\frac{2}{x^3} \right) none of which are finite as x\to x_0 Does this mean there are no regular singular points?
What's wrong with (x- 1)\left(\frac{2}{x^3}\right) as x goes to 1?
Doh - I've tended to 0 on every limit! :rolleyes:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
