Identifying Stresses in Structural Design
  • Thread starter Thread starter BurningUrge
The discussion centers on identifying stresses in a simplistic structural design involving a wireblock. The design is intended to fit snugly and be welded, with a safety factor of five times the designated load for durability. The main inquiry is whether shear stress would be present given the sliding slots in the design, as opposed to flat, wall-to-wall connections. It is noted that shear stress is generally always present, influenced by the orientation of the sample plane. The conversation highlights the complexity of accurately assessing stress without a detailed diagram.
BurningUrge
This isn't really a hard question, but it's been a while since I did this and I would just like to make absolute sure.
This is an exceptionally simplistic draft of a wireblock (open at one side to allow for wire to be threaded over while each side of the wire is attached to the ballast). It's not meant to be pretty, not meant to be advanced or anything of the sorts. Personally I was vastly better at everything related to Processing, Gas, Energy and Petroleum and whatnot when it came to Mechanical Engineering, so structural design was never quite my field of expertise.. but I digress.
Anyway, the point for me right now is to identify each stress. The pieces are meant to fit snuggly together and then welded. Assuming that the surface area of each "slot" that slides inside the openings of the other pieces is of adequate area to withstand the forces (it is designed to tolerate 5 times the designated load it would usually carry, for longevity purposes), and assume that the material is strong enough to resist the momentum bends.
The thing I wonder is, would this design encounter shearstress? I know it would if the pieces were just flat and put "wall to wall" and welded together. But with the slots for them to slide into, would this not remove shear stress from the equation?
Just take a look at the VERY basic paint-drawing I made. Ignore that it's clearly not evenly spread. Just imagine that the force down on the middle is directly below the force upwards.
https://ibb.co/mqQWMQ
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
