Does Subring Inherit Same Multiplicative Identity?
  • Thread starter boombaby
  • Tags
    Identity
In summary, the question is whether a subring should inherit the same multiplicative identity as the original ring, assuming that the definition of a ring requires a multiplicative identity. According to Rotman's book, the multiplicative identity 1 must be present in a subring. However, it is unclear whether this means the subring must contain the same multiplicative identity as the original ring or its own multiplicative identity. An example is given of Z_6 defined on Z by taking mod 6, where the subset S={3k| k is integers} is equipped with the same operations and has its own multiplicative identity of 3. The author wonders if S can be called a subring of Z_6, and it
boombaby
130
should the subring inherit the same multiplicative identity of the original ring? assuming multiplicative identity is required in the definition of ring.
according to the book (Rotman's), [tex]1\in S[/tex] is required. But, does it mean S contains the same multiplicative identity, or contains its own multiplicative identity?
Consider Z_6 defined on Z by taking mod 6. And its subset S={3k| k is integers} equipped with the same operations as in Z_6.
S is itself a ring, having multiplicative identity 3. I'm wondering if S is called a subring of Z_6?
It's a matter of convention. Most authors, when they require rings to have a multiplicative identity, will stipulate that a subring must have the same multiplicative identity as the ring.
Thanks a lot!
1. What is a subring and how does it relate to a ring?
A subring is a subset of a ring that is itself a ring under the same operations as the original ring. This means that it has the same elements and operations as the original ring, but may have a different identity element.
2. What is a multiplicative identity in a ring?
A multiplicative identity, also known as a unity, is an element in a ring that when multiplied with any other element, results in that element. In other words, it is the equivalent of 1 in regular arithmetic.
3. Does a subring always inherit the same multiplicative identity as the original ring?
No, a subring may have a different multiplicative identity than the original ring. However, it must still have a multiplicative identity that behaves in the same way as the original ring's identity.
4. How can we determine if a subring inherits the same multiplicative identity as the original ring?
To determine this, we can check if the subring's identity element is the same as the original ring's identity element. If they are the same, then the subring inherits the same multiplicative identity. If they are different, then it does not inherit the same multiplicative identity.
5. Can a subring have multiple multiplicative identities?
No, a subring can only have one multiplicative identity. This is because the multiplicative identity must be unique in order for the ring to be well-defined.
  • Linear and Abstract Algebra
