Improving IC Engine Efficiency: Reducing Heat Loss Through Cylinder Walls
The discussion revolves around improving the efficiency of internal combustion (IC) engines by addressing heat loss through cylinder walls. Participants explore the potential of using non-conductive materials, such as ceramics, to enhance thermal insulation and reduce fuel consumption. The conversation includes technical considerations, ongoing research, and the complexities of engine design.
  • Research-related
  • One participant suggests that a significant portion of efficiency loss in IC engines is due to heat conduction through cylinder walls and proposes using non-conductive materials to mitigate this.
  • Another participant mentions that ceramic cylinder liners could improve thermal insulation compared to traditional materials.
  • A question is raised about the actual efficiency gains from using ceramic liners and whether they can fully retain heat within the cylinder.
  • It is noted that while ceramics may provide better insulation, the cooling of the piston is also a critical factor in engine durability, complicating the design choices.
  • Participants discuss the ongoing complexity of IC engine research, highlighting that it has been a focus for over 125 years, with advancements often occurring in competitive environments like motor racing.
  • One participant points out that heat loss also occurs through exhaust gases and oil, suggesting that eliminating heat loss to cylinder walls could introduce new thermal stresses and require adjustments in oil capacity.
  • A clarification is made regarding the function of the spark plug, emphasizing that it ignites the fuel rather than the other way around.
Participants express various viewpoints on the effectiveness of using non-conductive materials and the implications for engine design. There is no consensus on the best approach to improving efficiency, and multiple competing views remain regarding the complexities involved.
The discussion highlights the intricate balance required in engine design, including thermal management and material properties. Assumptions about the benefits of non-conductive materials and their impact on engine performance remain unresolved.
Aneesh
hi.I would like to know something about the IC engine.I just read an article.It said that 30% efficiency is gone through conduction of heat by the cylinder wall.If it is reason for one of the efficiency loss why can't we build an cylinder coated with a material that is non conduction.So only little fuel is used to ignite the spark plug.
so what would be the efficiency of the engine if it is ceramic lined?.Does it fully keeps the heat inside the cylinder
Ceramic could do a better thermal insulation job than a cast iron sleeve with a water jacket. But is that what is really needed? An IC engine is a very complex interconnected compromise. Unfortunately, the piston must also be kept cool.
The durability of an engine depends on radiation of heat from the piston to the cylinder wall, along with splashing or spraying the inside of the piston with oil. It is normal for the cylinder head to have a water jacket, as does the cylinder sleeve. Only the piston has no direct cooling.
I hate to disillusion you, but there will be no sudden new discoveries by beginners in this field, apart from the educational breakthroughs in understanding, encountered while climbing the steep learning curve.
Jus to knw,is there any research undergoing regarding this?.I dnt know in what ways the efficiency is getting reduced.what are the factors?
Research continues, but the details are very complex.
IC engine research has been going on now for over 125 years.
http://en.wikipedia.org/wiki/Diesel_engine
After 90 years, the 24 hours Le mans trial continues to be run.
http://en.wikipedia.org/wiki/24_Hours_of_Le_Mans#Engines
Motor racing such as Formula One pushes the technology to the edge and keeps it there.
“Commercial in confidence” research continues behind closed doors.
Every now and then something new appears in the latest vehicles being mass produced.
Aside from losing heat to the cylinder walls, heat is also lost to the exhaust gases and oil. If there was no heat lost to the cylinder walls, you could run into thermal stresses that could warp the head and block. The engine would also need a larger oil capacity to keep the oil from over heating. More oil cooling means that you've lost heat to oil instead of water and you're back to where you started.
You got it the wrong way round. The spark plug ignites the fuel. Takes surprisingly little energy to do so.
  • · Replies 39 ·
  • · Replies 30 ·
  • · Replies 47 ·
9K
17K
39K
