How Do You Calculate the Impulse Received by a Football During a Kickoff?
  • Thread starter Thread starter Sumbhajee
    Impulse
To calculate the impulse received by a football during a kickoff, the mass of the ball (0.259 kg) and its final velocity must be determined. The ball travels a horizontal distance of 46 m at a launch angle of 47 degrees. The impulse can be calculated using the formula: Impulse = mass of the ball * final velocity. To find the final velocity, one must analyze the relationship between range, launch angle, and launch speed, as this is a projectile motion problem. Understanding these relationships is crucial for accurately calculating the impulse.
Sumbhajee
Calculate the impulse (in kg m/s) received by a football when it is kicked in a kickoff. The ball has a mass of 0.259 kg and travels a horizontal distance of 46 m. The ball is kicked at an angle of 47 degrees with the horizontal.
http://schubert.tmcc.edu/res/msu/mmp/kap6/picts/kick.gif
Impulse= mass of ball * velocity final for ball
I have tried solving this equation, but I cannot figure out how to find the final velocity of the ball. Any suggestions would be greatly appreciated. Thank you for your time. (It may be that the equation is incorrect.)
You have to determine the velocity of the ball at launch from the data provided. This is a projectile trajectory problem but in reverse: you are given the trajectory distance and initial direction and you have to find the initial speed.
What is the relationship between range, launch angle and launch speed?
AM
