In a cylinder, why do we use just the ground area to get p?
The discussion revolves around the application of pressure in hydraulic cylinders, specifically addressing why the force is calculated using the area of the piston rather than considering the entire surface area of the cylinder. Participants explore the relationship between pressure, force, and the geometry of the cylinder in the context of hydraulic systems.
  • One participant questions why the force is calculated using the piston area (F=p*A) when pressure should theoretically act on all surfaces of the cylinder, suggesting that this could lead to a smaller force than calculated.
  • Another participant clarifies that the pressure indeed exerts force on all surfaces, but emphasizes that when calculating work, the relevant area is the piston surface, as it is the one doing the work against a force.
  • A later reply acknowledges the initial confusion and corrects the misunderstanding about how force and pressure interact across different surfaces within the cylinder.
Participants express differing views on the implications of pressure acting on multiple surfaces within the cylinder. While some clarify the role of the piston area in work calculations, the discussion does not reach a consensus on the broader implications of pressure distribution.
Participants do not fully resolve the implications of pressure acting on all surfaces versus the specific application of piston area in work calculations, leaving some assumptions and interpretations open for further exploration.
MicroCosmos
Hi,
given an Hydraulic Cylinder with the Formula:
F=p*A
Why do we use APiston to calculate the Force in Work-Direction? Doesnt it suppose the "Potential Energy" of the compressed air just presses in that Area?
Im pretty confused, sorry about the unconcrete question.
The potential energy of the compressed air is what causes the p in your equation. Can you re-state your question? I am not sure what you are asking.
The fact is that a Zylinder is built with 2 circles and 1 rectangle. But when i look for the formula that calculates the Force applied to one of the circles (Like Piston with compressed fluid work) depending on the Pressure, i find everywhere: F=p*ACircle, where A is the Area of that circle. My question is: isn't it wrong? because the pressure schould cause Force in all surfaces, it should distribute among all of them, causing an smaller Force than F=p*ACircle tells me.
There is a force pushing against the piston surface that is p(area of the piston surface).
There is a force pushing against the wall of the cylinder that is p(area of the cylinder wall).
It is not an either / or, the pressure presents a force against all surfaces of the interior of the cylinder, and the force against any part of that interior surface is the pressure times the area of interest.
Work is force * displacement, so when calculating work, the relevant area to use is the piston surface, because that is the surface that is involved in doing work, because it is displacing against a force.
As the piston moves up, the p decreases, of course, since the volume of the interior of the cylinder is increasing. This is where you are getting your spring analogy from, I think.
I understand what you mean, i was confused, thanks a lot. I thought the fact that a Force acts in a surface means there is less pressure for the others to hold. That is of course not true.
  • · Replies 19 ·
  • · Replies 45 ·
  • · Replies 27 ·
