Engineering In circuit analysis, is current through wires defined?
In circuit analysis, the resistance of wires is often simplified to 0 Ω, leading to the assumption that the potential difference along the wire is also 0 Volts. This does not mean that current through the wires is undefined; rather, current is determined by the other circuit components that have higher resistance. While the wire's resistance is negligible, it does not imply that current is infinite; instead, it is finite and dictated by the overall circuit configuration. Real-world scenarios, such as a battery's internal resistance, illustrate that even with ideal wires, current can be calculated using Ohm's Law by considering the effective resistance in the circuit. Thus, in practical terms, the current through wires is influenced by the surrounding components rather than being zero or infinite.
ee15
This is not a homework problem, but related to my circuits class.
In the typical electrical engineering simplification, the resistance of wires in the circuit is taken to be 0 Ω. Also, the potential difference between two points along the same wire is 0 Volts.
Does this mean that current through wires is undefined? Would engineers consider the current zero or infinite?
voltage = current * resistance
Maybe Ohm's Law does not apply here, and there is another way of looking at the situation.
wires in circuits generally have such a tiny resistance relative to that of the other objects in the circuit that their effect is negligible. Why would you expect otherwise? circuit analysis becomes unnecessarily complicated if you add in the tiny amounts of loss due to wires.
ee15 said:
1. In the typical electrical engineering simplification, the resistance of wires in the circuit is taken to be 0 Ω. Also, the potential difference between two points along the same wire is 0 Volts.
The wire can be considered to have zero resistance and the current still finite because V = IR but if R → 0 then V = 0 for any finite I. I is determined by other impedances in the circuit containing the zero-R wire.
In reality there is always some finite R for any wire (and inductance too, and some capacitance to nearby nodes ...) and for a stretch of such a wire V = IR still holds.
In circuit analysis (at least when Faraday's law doesn't apply), you may assume that the wires are inexistent and that all your components connect directly where they need to.
Neither. You would need to consider the circuit as a whole...
In this case the resistance of the wire (0 Ohms) is going to be much less than other circuit elements that are in series with the wire. Those other circuit elements will dominate the overall resistance and the current flowing. The voltage drop down the wire is not the same as voltage source.
Imagine you have a real world battery. These behave like an ideal voltage source (Videal) in series with a small resistor representing the internal resistance of the battery (Rint). let's say that's 0.1 Ohms.
If you short out the battery using your ideal wire the current will be...
Ishort = Videal/(Rint + Rwire)
Rwire = 0 so
Ishort = Videal/Rint
The voltage drop down the ideal wire is 0V. The resistance of the wire is 0V but the current is Videal/Rint.
12K
