What is the Normal Force on an Incline Plane with Two Connected Blocks?
  • Thread starter Thread starter Alex126
    Incline Pulley
The discussion focuses on calculating the normal force on an incline plane with two connected blocks, where block m1 (0.23 grams) is on the incline at a 30° angle, and block m2 (0.18 grams) is hanging. The normal force is determined using the Y-axis component of the weight of block m1, leading to a calculation of 1.96 N. However, doubts arise regarding whether the second block affects the normal force, which is clarified by emphasizing that each block's forces should be analyzed independently. The calculated acceleration indicates that block m1 moves up the incline with an acceleration of +1.55 m/s², confirming the system's dynamics. The tension in the system is also calculated to be +1.48 N, consistent across both equations derived from the forces acting on the blocks.
Alex126
On an incline plane of known angle α (30°) lies a block of mass m1 (0.23 grams), connected through a pulley without friction to a second block of mass m2 (0.18 grams). Determine:
- The acceleration of the block
- The Tension force
- The Normal force of the plane
F = m*a
The simplest of the requests is actually the one that troubles me the most. The Normal force of the plane should be:
Normal = -Weight1_Y
(Weight1_Y = Y-axis component of the weight force of the first block)
Therefore, Normal = Weight 1 * cos (30°), so Normal = 0.23*9.81*0.87 = 1.96
As simple as it should be, I have some doubts that there might be more to it, such as some sort of influence on the Normal force by the second object in the system.
So, in other words, I'm asking if the Normal force in this case is still just -Weight1_Y, or if there's something else to consider.
Also, note that the problem asks the "Normal force of the plane", so if there is any other "Normal force", other than the plane's reaction to the Weight force (Y component only) of the body that lies on it, please let me know.
First I have to write the forces for each body individually.
1. [Tension] + [Weight 1] + [Normal] = m1*a
2. [Tension] + [Weight 2] = m2*a
Choosing +X towards the motion (assuming block m1 is sliding down), and +Y upwards (assuming block m2 is going up), this would become:
1. -T + W1_X + W1_Y - Normal = m1*a
2. +T - W2 = m2*a
The #1 becomes (W1_Y - Normal = 0): T = W1_X - m1*a
The #2 becomes: T = W2 + m2*a
Solving the system, we have W1_X - m1*a = W2 + m2*a, so:
a = (W1_X-W2) / (m1+m2)
a = (0.23*9.81*sin (30°) - 0.18*9.81) / (0.23-0.18)
a = -1.55
Since acceleration is negative, it means that the motion happens in the direction opposite the chosen axis system. Therefore, I conclude that the block m1 doesn't actually slide down the incline plane, but actually goes up the plane with an acceleration of +1.55 m/s2
Normally I wouldn't have a problem with this conclusion, but I just want to make sure.
Anyhow, the Tension is then calculated from the same system, for instance the first equation, so:
T = 0.23*9.81*sin (30°) - 0.23*(-1.55)
T = +1.48
Same number results from T = W2+m2*a (0.18*9.81+0.18*(-1.55))
I didn't fully read your question as formulas are not tidy.
Please look at my attached material which might help you, I think.
Fundamental principle: each rigid body in the system responds to those forces which act on it directly. It cannot know or care about other forces. This is why it's a good idea to draw a separate free body diagram for each rigid body in the system.
Not that I can see.
Right.
Ok, thanks.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
