What Forces Affect the Motion in an Inclined Pulley System?
The discussion revolves around calculating the motion of a physics book on an inclined plane connected to a coffee cup. The book, with a mass of 1.0 kg, is pushed up the slope at 3.0 m/s, and the coefficients of friction are given as Us = 0.50 and uk = 0.20. The calculations involve determining how far the book slides, whether it sticks or slides back down, and the forces required for each scenario. After resolving the equations of motion, the answers concluded that the book slides 0.65 meters, slides back down, and requires a force of 4.63 N to stick. The participant plans to clarify the last question's wording with their professor.
azn_oohwee
I am having a problem finding the last part of this problem, and I'm not really sure if I did the first part right.
The 1.0 kg physics book in Figure P8.38 is connected by a string to a 600 g coffee cup. The book is given a push up the slope and released with a speed of 3.0 m/s. The coefficients of friction are Us = 0.50 and uk = 0.20.
http://www.webassign.net/knight/p8-38.gif
(a) How far does the book slide?
(b) At the highest point, does the book stick to the slope, or does it slide back down?
If the book sticks, what magnitude of force along the incline is required to make it slide down? If the book slides, what magnitude of force along the incline is required to make the book stick?
So this is what I did.
For the cup
∑(Fc)y = T - mg = ma
For the book.
∑(Fb)y = N - mgcos(@) = 0
∑(Fb)x = -T - fk - mgsin(@) = ma
∑(Fb)x = -T - uk(m(b)*a + (m(b)*g) - m(b)sin(@) = m(b)a
I add the cup to the book.
-m(a)g - uk(m(b)*a + (m(b)*g) - m(b)sin(@) = m(b)a + m(c)a = a(m(b) + m(a))
-{ g(m(a) + uk(m(b)*a + (m(b)*g) - m(b)sin(@) } / { m(b) + m(a) = a
after solving for acceleration I use a to find delta x
Vf = 0, Vi = 3 so
0 = (3)^2 + 2a(deltaX)
deltaX = -9/2a
so that gives me (a)
For (b) I reason the book slides back down.
And for C I'm having trouble visualizing how to set up the problem
I'm setting it up like this
Components to the left:
Tension
Ma
Mgsin@
Components to the right:
static friction
and the force?
I just need a little help on this one. Anything will be greatly appreciated. Thanks.
For the cup
For the book.
I do not understand your last equation. Why did you replace friction by uk(ma +mg)? Friction is N*uk.
ehild
oops sorry..
I meant to write..
∑(Fb)x = -T - ukN - mgsin(@) = ma
N = mgcos@ so
∑(Fb)x = -T - ukmgcos@ = ma
-m(a)g - uk(m(b)gcos@ - m(b)gsin@ = m(b)a + m(c)a
a = - { g(m(c) - uk(m(b)cos@) - m(b)sin@ } / {m(b) + m(c) }
That should be more correct.
I have the answers to the problems now. The last question was a bit vague on the wording, i'll have to ask my professor about that one.
(a) 0.65m
(b) slide back down
(C) 4.63N
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
