Calculating EMF in Steel Beam Impact Before Landing
The discussion revolves around calculating the electromotive force (emf) generated in a steel beam dropped from a height of 9.51 meters, with a length of 11.2 meters and a horizontal magnetic field of 18.5x10^-6T. The area of the beam is calculated as 53.36 m² using the formula for the area of a triangle, but its relevance to the emf calculation is questioned. The equation e = magnetic flux/time is referenced, yet the absence of a time variable complicates the solution. Participants express uncertainty about how to incorporate time into the calculation, and there is a consideration of the forces acting on a test charge within the beam. The discussion highlights the challenge of applying theoretical equations to practical scenarios in electromagnetism.
xswtxoj
A 11.2m long steel been is dropped from a height of 9.51m. The horizontal component of the Earth's over the region is 18.5x10^-6T. What's the emf in the beam impact just before the impact with the earth, assuming its long dimension remains in a horizontal plane, oriented perpendicularly to the horizontal component of the Earth's magnetic field?
e= mag flx/t
A= 1/2*b*h
A=1/2 x 11.2 x9.51= 53.36
18.5e-6* 53.26
but there's no time
e= mag flx/t
A= 1/2*b*h
That would be the area of a triangle, but I fail to see the relevance?
18.5e-6* 53.26
but there's no time
My own hunch is that the electric and magnetic forces on a test charge Q in the beam would have to be equal in magnitude, opposite in direction.
So, what is the magnetic force on a charge Q?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
