Infinite sheet of dielectric
In summary, the problem from I.E.Irodov's Basic laws of electromagnetism involves finding the magnitude of \mathbf{E} and the potential \varphi as functions of distance x from the middle of an infinitely large plate made of homogeneous linear isotropic dielectric with dielectric constant \epsilon, which is uniformly charged by an extraneous charge with volume density \rho > 0 and thickness 2a. The author presents a solution based on symmetry considerations, stating that \mathbf{E} is zero in the middle of the plate and perpendicular to the surface at all other points. The equations \vec{\nabla}\times \vec{E} =0, \vec{\nabla}\times
issacnewton
1,000
29
Here is the problem from I.E.Irodov's Basic laws of electromagnetism.
An infinitely large plate made of homogeneous linear isotropic dielectric with dielectric constant
[itex]\epsilon[/itex] is uniformly charged by an extraneous charge (see footnote) with volume density [itex]\rho > 0[/itex].The thickness of the plate is 2a. Find the magnitude of [itex]\mathbf{E}[/itex] and the potential [itex]\varphi[/itex] as functions of distance x from the middle of the plate (assume that the potential is zero at the middle of the plate).
Now the author has given the solution in the book . I am just trying to understand it. He says, "From symmetry considerations it is clear that E=0 in the middle of the plate, while at all other points vectors [itex]\mathbf{E}[/itex] are perpendicular to the surface of the plate"
I am trying to see this from more mathematical arguments using the typical equations involved here.
[tex]\vec{\nabla}\times \vec{E} =0[/tex]
[tex]\vec{\nabla}\times \vec{D}=\vec{\nabla}\times \vec{P}[/tex]
[tex]\vec{\nabla}\bullet \vec{D}=\rho_f [/tex]
How do I proceed ?
footnote: Extraneous charges are frequently called free charges , but this term is not
convenient in some cases since extraneous charges may be not free ( this is author's footnote and I don't really understand what he means by it)
Do you understand what the "symmetry considerations" here are?
[itex]\vec{\nabla}\times \vec{E} =0[/itex] ...(1)
[itex]\vec{\nabla}\times \vec{D}=\vec{\nabla}\times \vec{P}[/itex] ...(2)
[itex]\vec{\nabla}\cdot \vec{D}=\rho_f [/itex] ...(3)
How do I proceed ?
Free charges means not polarization charges.
You want equation 3.
Choose a coordinate system and write it out.
Solve the resulting differential equations for each region (you have three). D has to be continuous across the boundaries but E does not.
Consider: how would you go about this problem if you replace the dielectric with an insulator?
footnote: Extraneous charges are frequently called free charges , but this term is not convenient in some cases since extraneous charges may be not free ( this is author's footnote and I don't really understand what he means by it)
"free charge" means "not polarization charges".
Simon Bridge said:
Do you understand what the "symmetry considerations" here are ?
I can see that sheet is symmetric about the axis going through the middle. But other than
that I don't get symmetry considerations as the author says.
So equation 3 would be kind of a Poisson's equation where [itex]\rho_f[/itex] is constant
inside the dielectric, right ?
Isn't an insulator a form of a dielectric ?
so does it mean that extraneous charge may or may not be polarization charge ?
Try sketching the situation with the field lines.
The slab has "rectangular symmetry" which means you pick Cartesian coordinates.
If you try it, you'll find that two of directions have vanishing contributions, so it turns into a 1D problem.
So equation 3 would be kind of a Poisson's equation where [itex]\rho_f[/itex] is constant inside the dielectric, right ?
I take it you have not done this for an insulator then?
Usually these are given as an exercise before you do dielectrics.
It normally goes: single-charge, charges on a conductor, uniform charge density through an insulator, then dielectrics.
Charges don't move in an insulator, but simple insulators don't have polarization charges to speak of. It's a way of getting students to consider things other than a thin shell of charge.
Suggest you go see how these are done - go back over your class notes.
Have a look at these notes - scroll down for example 2.4.
Or this problem.
Once you know how to do it just for E, you can do it for D.
Simon, is it possible to use symmetries about the laws of physics in general. For example, if I choose the axis going through the middle as z axis, and if we rotate this sheet about this z axis, then since the charge distribution around this z axis is symmetric, the field lines should be symmetric too. That would eliminate lot of weird lines. Also we can talk about the reflection in the mirror located at z=0. That should also keep the field lines invariant, since after the reflection, the charge distribution is symmetric.
I had read somewhere about such arguments in physics. I don't know what they are called
What is an infinite sheet of dielectric?
An infinite sheet of dielectric is a theoretical concept used in physics and engineering to model the behavior of a sheet of material that has a non-zero dielectric constant, meaning it can store and transmit electrical energy.
How is an infinite sheet of dielectric different from a regular sheet of material?
An infinite sheet of dielectric has a uniform distribution of charge and a constant electric field throughout its entire surface, whereas a regular sheet of material may have varying charge densities and electric fields depending on its composition and shape.
What are some real-world applications of an infinite sheet of dielectric?
An infinite sheet of dielectric is often used in the design and analysis of capacitors and other electronic components, as well as in the study of electromagnetic fields and wave propagation in materials.
How does an infinite sheet of dielectric affect the electric field around it?
An infinite sheet of dielectric can either enhance or weaken the electric field around it, depending on the direction of the electric field and the dielectric constant of the material. It can also cause the electric field to bend or refract as it passes through the sheet.
Is an infinite sheet of dielectric a realistic model?
No, an infinite sheet of dielectric is a simplified theoretical model used to study the behavior of materials with non-zero dielectric constants. In reality, materials have finite dimensions and boundaries that can affect their electrical properties.
