Initial phase determination in a wave
The discussion revolves around solving a wave equation to determine its amplitude and initial phase. The wave equation provided is a combination of cosine and sine functions, and the user is tasked with proving that the amplitude is 0.05 meters and the initial phase is -π/4, given specific values for angular frequency (w) and wave number (k). The user attempts to use phasor addition and trigonometric identities but struggles to derive the correct phase. They express confusion about converting sine to cosine forms and seek guidance on the correct approach to prove the required parameters. The conversation highlights the challenges of applying trigonometric identities in wave analysis.
Jos_Moreira
I'm having trouble solving the following exercise:
Given the following wave equation:
y=0.01cos(wt-kx)+0.02*6^(1/2)sin(wt-kx)
prove that if w=16s^-1 and k=6m^-1 then the amplitude of the wave is 0.05 meters and the initial phase is -pi/4 how can I prove that? By phasor addiction probably but I can't go far that way. can someone show me how to do it?
Thank you
I converted sin(wt-kx) to cos(wt-kx-pi/2) so I can write the phasor corresponding to each cosine and attempt to add then an see what I get back, but what I get back I the equation I started with with the cos(wt-kx-pi/2) back as sin(wt-kx) by looking att the trignometric identity: acos(A)+bsin(B)=\sqrt{b^2+a^2}*sin(A+C) where C is arctan(\frac{b}{a}) i could get the amplitude, but the phase I get is diffrent.
can't you use trig to turn cos(A-B) into cosAcosB+sinAsinB, turn sin(A-B) to sinAcosB-cosAsinB
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
