Inner Product, Triangle and Cauchy Schwarz Inequalities
The discussion revolves around the triangle inequality and Cauchy-Schwarz inequality in the context of inner products. Participants express uncertainty regarding the application of these inequalities specifically for inner products, referencing definitions of norms and distances derived from inner product axioms.
  • Participants explore the relationship between inner products and norms, questioning how to demonstrate the triangle inequality and Cauchy-Schwarz inequality. There is discussion about the appropriate expressions to use, such as whether to consider #### or ## + ##.
Some participants provide guidance on how to approach the problem, suggesting that the triangle inequality can be shown by examining the norm of the difference between vectors. Others raise questions about the definitions and the reasoning behind using certain forms of the inequalities.
There is mention of specific examples and definitions from lecture notes and textbooks that may not cover the inequalities in question, leading to some confusion among participants. The discussion also reflects a mix of attempts to clarify terminology and explore the implications of the inequalities.
Lelouch
I am not sure. I have not seen the triangle inequality for inner products, nor the Cauchy-Schwarz Inequality for the inner product. The only thing that my lecture notes and textbook show is the axioms for general inner products, the definition of norm (length) and distance between inner product. And some basic consequences of the inner product axioms for norm and distance, s.t. norm is greater equal to 0, norm multiplied by a constant, symmetry of distance, and distance is greater than or equal to 0.
The rest are examples of inner products i.e. on ##R^n##.
I have solved the definite integral for the given ##p(x)## and ##q(x)## which has the value ##\frac{68}{21}##.
What I thought I need to show is that ##<p, q> \leq <p> + <q>## for the triangle inequality. But this seems nonsensical to me since the inner product is defined for two vectors and not for one.
Maybe I have to show ##<p, q> \leq <p, p> + <q, q>##? But at this point I am just guessing since I do not know the triangle inequality for inner products nor the Cauchy-Schwarz inequality for inner products.
Yes, an inner product defines an associated norm ||a|| 2= <a,a>. The triangle they are talking about is p, q, and p-q. To show that the norm satisfies the triangle inequality for that triangle, show that ##√<p-q, p-q> \leq √<p, p> + √<q, q>##.
I wanted to ask why the norm was defined as the inner product, but now right before I answered I noticed you added the ##\sqrt{}##.
It seems simple I just calculate the respective inner products using the integral, then square root and check whether the inequality holds for the numerical values.
However, why do we perform ##<p - q, p - q>## instead of ##<p + q, p + q>## as shown in Theorem 1(a) in the following link?http://mathonline.wikidot.com/the-triangle-inequality-for-inner-product-spaces
Since any of the three sides of a triangle is no longer than the sum of the lengths of the other two sides, both triangle examples work.
Get the terminology straight first, before attempting the question. For any two vectors ##p,q##:
1. Triangle inequality: ##|| p + q || \leq || p || + || q ||##.
2. Cauchy-Schwartz: ##|\langle p,q \rangle | \leq || p || \cdot || q ||.##
Here, ##\langle \cdot , \cdot \rangle## is the inner product and ##||w|| = \sqrt{\langle w,w \rangle }## is the associated "norm".
In your case the easiest thing is to just do all the integrals and show that you get the above inequalities with the given ##p,q##.
Thank you. I was able to solve the problem given your explanation of the terminology.
