Input and output resistance of common collector
In summary, the input resistance of a common collector circuit is the ratio of the change in input voltage to the resulting change in input current, while the output resistance is the ratio of the change in output voltage to the resulting change in output current. The input resistance can be calculated by dividing the emitter voltage by the change in emitter current or by dividing the collector voltage by the change in collector current. The input and output resistances are significant in determining the overall gain and stability of the circuit, with a higher input resistance resulting in a higher voltage gain and a lower output resistance providing a more stable output voltage. These resistances also affect the frequency response of the circuit by acting as filters, with a higher input resistance resulting in a lower frequency response and
Have a look at this:
http://people.seas.harvard.edu/%7Ejones/es154/lectures/lecture_3/bjt_amps/bjt_amps.html
Does that help?
it does a little.
I figured out my problem. it had to do with the resistance reflection rule.
thanks for the reply though
1. What is the definition of input and output resistance of a common collector circuit?
The input resistance of a common collector circuit is the ratio of the change in input voltage to the resulting change in input current. The output resistance is the ratio of the change in output voltage to the resulting change in output current.
2. How is the input resistance of a common collector circuit calculated?
The input resistance can be calculated by dividing the emitter voltage by the change in emitter current. This can also be calculated by dividing the collector voltage by the change in collector current.
3. What is the significance of the input and output resistances in a common collector circuit?
The input and output resistances are important because they determine the overall gain and stability of the circuit. A higher input resistance can result in a higher voltage gain, while a lower output resistance can provide a more stable output voltage.
4. How does the input and output resistances affect the frequency response of a common collector circuit?
The input and output resistances can affect the frequency response of a common collector circuit by acting as filters. A higher input resistance can result in a lower frequency response, while a lower output resistance can result in a higher frequency response.
5. Can the input and output resistances of a common collector circuit be adjusted?
Yes, the input and output resistances can be adjusted by changing the biasing resistors and the load resistance. By changing these resistances, the overall gain and stability of the circuit can be modified.
